KPG-22U alternative
KB1VLA
South Berwick, ME
Hello,
I'm in the market for an aftermarket alternative to the Kenwood KPG-22U cable. Can anyone recommend a good quality item? I'm a little gun-shy about the Chinese stuff from eBay and Amazon.
EDIT: I should add I'm attempting to program and NX-220 with KPG-141DN.
buddrousa
NW Tenn
Your options are buy the factory Kenwood cable or trust a clone cable. If you are programming only a clone should work great for you. If you want to do FIRMWARE then I would go with the Kenwood factory cable.
kd4efm
Florida
And they are not that expensive. Get the real deal.
Sent from my SM-G935P using Tapatalk
SNCZCA01DS0
I agree, get the real one. They are built very well and I've never had any issues with the real Kenwood stuff.
However, at over $100.00 for a brand new one, it's kind of step if you just want to program one radio. It's kind of a risk thing. Lot's of people have had good luck with the after market ones on many different radio brands so they aren't all bad. As for not finding a Chinese one, not sure how to determine that.
kayn1n32008
ØÆSØ
Sector 001
I have 3 aftermarket USB cables that I use for my Kenwood radios. I have even done firmware updates on a couple mobiles with out issue. Unless you have an old radio that requires DOS to program it, get USB cables. These are not old Motorola radios, that are hit and miss with aftermarket cables, they are Kenwood, and every Kenwood I have programmed have been with aftermarket cables, and had no failures. I have programmed: NX-700, NX200, TK-7180, TK-8180, TK7160, TK-760, TK-2170, TK-2212, TK-2202, TK-270(G), TK-280, TK-380. Not one failure, all with aftermarket USB cables. I do not even own an OEM Kenwood programming cable.
Sent from my iPad using Tapatalk
KK6ZTE
California
Interesting experience.
I take it you haven't had issues with the aftermarket cable's TTL conversion chip causing the radio to transmit randomly when the programming cable is inserted and idle? I've got half a dozen of them and they all do that. The factory Kenwood cable doesn't have that "feature".
kayn1n32008
ØÆSØ
Sector 001
Nope. Not once. On any of my radios.
KB1VLA
South Berwick, ME
Thanks for the responses everyone. I actually had a Chinese cable that came with an older HT, but it didn't work. However, I tried backdating the drivers, and I was in business! Cheap cable worked just fine.
