KPG 74D and windows 7?
btritch
Paragould/Greene County AR
I don't really need to be able to page out on it, I just want it to activate when a tone is recieved, Anybody know how to do that on a 7160? Or how long it needs to be set at?
code3cowboy
CA-CZU
You need to know the frequency and duration of your tones, then plug them into the 2 tone 1 field in the 2 tone menu. Select 2 tone 1 as the signaling on the channels you may be paged out on, and decide between the "and" and the "or" signaling.
btritch
The duration I believe is 5 seconds. One of the tones is 1185.2 and the other 584 I believe.. I'll have to check. It doesn't necessarily have to be done, Just thought it'd be nice. They are motorola Quick Call Tones From Reed Group 6 I believe. Just one long tone when it doesn't activate anything. Do I need to change it from 2 tone 1 to single tone?
Blue Mound
Hello, I'm trying to use KPG 74D software with windows 7. It installed and opened up just fine, and to connect the computer to the radio, I'm using a USB to serial adapter, which is connected to to the computer via usb and to the programming cable via serial, then on to the radio.
When I try to read the radio, It says "Can not open com port", Also will not open help or any other topics contained within the software.
I heard this program would not work with anything past windows XPS.
Any thoughts or ideas?
throw away that cord and buy a serial port cord. it works alot better. may also be windows 7
No, I think I'll keep the cord. It works awesome now. Just had to go into drivers and devices and change a few settings, Now it works just fine every time I plug it in.
