KPG-89D Won't Save File???
stevez97
Myrtle Beach, South Carolina
I've been using this software to program my TK-7180 for years. Made some changes yesterday and today and software reads/writes fine. Saved the file today and went to reopen and found the file blank. Tried a couple times with same result.
Re-installed the software and getting same result.
Any ideas?
Thanks for your thoughts.
Hmmm, not sure. My KPG-89 is on my PC at work. I'll try to play around with it on Monday.
XTS3000
Not sure what OS your using, but try to right click on the exe and select “run as administrator”. That may solve your save problem.
DJ11DLN
Mudhole, IN
You may just need a clean install. I had one of the KPG programs on my computer go wonky a few years back, I don't recall now exactly which one or what the aberrant behavior was (did I mention it's been several years?) but uninstalling it and deleting all traces, followed bu a clean install, solved the problem.
KK4JUG
GA
A couple of weeks ago, I tried to re-program my Yaeau FT-8900. Would not complete the write to the radio. A simple reboot of the computer took care of it, I was using an Acer netbook with Windows 7. That's about all l use the computer for. It has a flock of "programming programs" on it,
Try the reboot.
