KPG-D1N from one computer to another
KD2DXF
Nobody
Anytown, USA
My apologies if this has been discussed before. I wanted a thread to discuss the process of moving the KPG-D1N software/license from my old laptop, to new one. I only use it for one radio setup. Is this possible, or do I need to purchase a new Key for new Laptop.
a417
I believe it needs to be deactivated on the computer you are on, then it can be reactivated on the new laptop. There are many people on here who can speak authoritatively on that.
Cognomen
Radioactive Zone
It's easy. Deactivate using License Management Client. Install D1N on the new computer and activate with LMC. You do not need to uninstall D1N from the old computer, just deactivate.
kd4efm
EL98 Florida
It would also help to have you LMC activated with an account key (free by the way), that also will allow you to push radio features in the future.
I be my own rule offer a 5 seat set up so you can have 5 chances of being able to recover your software at the worst possible times.
That being said, there IS NO limit to the number of PC per account key. 1 to xxxx, but rule of thumb is for a single person, 5 is usually good.
NOTE: even with the LMC registered, radio features are a 1 time deal after 72 hours, that key belongs to that radio forever.
Some people will stress over there list having a key that says 0/1 and cant figure out how to pull it from the radio. Does not work that way.
Contact your local dealer or I can guide you on more information 1 on 1.
imow; does not hurt to get your LMC account key (jkefa) so you can move about pc's with your software.
*NOTE: WIDE BAND KEYS CAN NOT BE RECOVERED DUE TO ELECTRONIC FAILURES!
lmn1tjd131
Connecticut
Make sure to write down the machine code for each PC you use the software license on and save somewhere safe. My laptop drive blew up with the license active on it and I didn't have the machine code for it. Luckily I only had used it on two different machines. Kenwood deleted the machine code for my broken PC and restored my ability to use again on the other machine. Probably a good practice to deactivate the license after each use regardless.
