KPG-D1N/NX-5900 Programming Questions
okgatorfan
ELMORE CITY
Setting up a new NX-5900 that will have two separate P25 trunked systems in it, with both systems being in one zone. Trying to setup for MULTI ZONE SCAN under the ZONE EDIT, but that option is not there, unlike what the HELP MENU tells me. NONE, SINGLE, and LIST are shown. Am I missing something?
2. Is there an easy way to rearrange the ZONE layout? I have tried and tried to do the COPY/INSERT, and followed the HELP menu here as well, but to no avail.
3. ANALOG CONVENTIONAL PERSONALITY CTCSS: Is there a way when you have a TALK AROUND channel in an ANALOG CONVENTIONAL PERSONALITY to set the RXPL to CSQ, while having the TXPL set to CTCSS? I know that NAC codes can be changed in a P25 personality in TA, so why not in an ANALOG?
No. And I've gone around and around with Kenwood on this, you are welcome to pick up where I left off.
kd4efm
EL98 Florida
must be using personality mode versus channel table
2 separate p25 trunk systems in one zone only way you can go about this.
multi zone scan; only in conventional zones
when in a trunked zone, (with a valid system) you cant scan off the control channel to a conventional by design.
