First, I want to thank the folks here (and you know who you are) that have PM'd me with helpful advice on programming the new NX-5x000 radio decks that I just acquired. The files you shared were most instructive and I've got rudimentary files build for both the VHF and UHF decks I own, that I will refine (in terms of options and personal features) over the weekend.
In the process of learning programming, I also figured out a workaround for copy-and-paste for this software, at least until Kenwood builds it in. This let me quickly copy almost everthing from my Kenwood TM-D710GA, instead of entering frequencies and tones one line at a time (which would have taken, conservatively, 15 years).
I also figured out that you can move Zones around in the order. Select the Zone, and using the 'Copy' command at the top left, Copy the zone to the end of the order, delete the original Zone and then rename the new copy. Arcane to be sure, but you can shuffle things around until you get the order you want. Now I just have to remember that the 'Add' commant lets me insert Zones into the hierarchy where I want them, and I can keep all this straight (and all my DMR zones in order).
What I did to Copy-and-Paste (distinctive to my own situation, but you'll get the idea) as a workaround:
1. Export all the frequencies from my TM-D710GA to a .CSV file, using RT System programming software (I also have Kenwood's software but didn't try it - it says it does the same thing).
2. Save it to the desktop and open in Excel (Office 2016, in my case) as a .CSV file. DO NOT save as .XLSX or anything.
3. Create a copy of the sheet in the same file (down at the bottom, where the tabs and the '+' sign are), and sort out the VHF frequencies I want to move. This takes it from a combination VHF/UHF file of 600 rows to a VHF file of 250 rows (in my case, anyway, but I do live in Los Angeles and there are repeaters everywhere and a whole lot of hills).
4. Open a new third blank sheet (tabs at the bottom, and the '+' sign).
5. Go to KPG-D1N and to the Zone/Channel table for the Zone in which you want the frequencies .
6. Copy the Channel table. Paste the table into this new third sheet.
7. This gives you a table in the new third sheet where the first row is the exported names for the columns, and rows 2 through the end are blank.
8. Go to the second sheet (sorted list of VHF frequencies). Copy the column with the receive frequencies you want in this particular Zone.
9. Go to the third sheet, select the first open cell in row 2 under the column for receive frequencies. Right-click and select "Paste values" and you'll see all the values paste themselves into the third sheet table as raw numbers.
10. Back to the second sheet. Select the transmit frequencies the same way. Paste into the third sheet as 'Values' beginning with the first cell in row 2 under column B (transmit frequencies).
11. In column C, D and E, because this was an analog Zone, I manually typed Analog, Analog, High in each cell in Row 2 under column C, D and E. Then I duplicated it down to the last row if frequencies (row 34, for example). I imagine that, if this was a DMR Zone, you would type DMR, DMR, High in each cell in column C, D and E and the Paste function would create a DMR channel. I haven't tried that. Yet. (FWIW, all my Analog Zones are set up as "DMR Conventional" Zones so I can mix and match frequencies and modes if I want.)
12. Leave all the other columns blank until you get to the 'Name' column (G? Not looking at the KPG-D1N right now). Copy the names of the channels from the second sheet to the third sheet as before, pasting as 'Values' only. Or leave it blank if you want to write new names after copying.
Now the channel table should be what you want to see in the NX-5x00 Zone.
13. In the Excel third sheet, copy from row 1 (with the field names) down to the end of the table with rows that have entries (row 34, in my case). Copy the entire row, not just the cells or columns with data. I selected the entire set of rows and hit "Cntrl-C" (Copy) on my Windows machine.
14. Go to the KPG-D1N, to the Zone on which you want the frequencies, and to the channel table in that zone. Select the first row. The first cell in the first row will get highlighted, but nothing else.
15. Hit 'Cntrl-V' (Paste). Wait. The table from Excel will get copied into the KPG-D1N, but not the first row with the names of the fields. In Copy-and-Paste that seems to just orient the KPG-D1N to what goes where. Row 1 from the Excel table just seems to disappear in the KPG-D1N.
16. You'll have to edit the PL independently. I tried copying it but got goofy entries. You can put "None" and it seems to copy correctly, but putting a tone like 100.0 Hz shows up as 10.0.
17. SAVE the file in the KPG-D1N. If you are continuing to copy/move fequencies, do not save the Excel file, because that adds formatting to the cells. In my case, after I copied the frequencies over into the Zone I wanted to fill up, I cleared the table (rows 2 through 34) and then did another Zone. Got about 400 channels programmed in an hour.
18. Of course, this isn't yet loaded in the radio decks, but it sure looks correct. We'll see what happens after I try to do that over the weekend.
I want to try this to copy Individual IDs from Excel - that's for tonight (and if I can distill by list of 500 IDs down to 100 so they fit). Using this approach, it should work.
Of course, if anyone knows how to expand the Individual ID list to take that many entries, I sure want to know about it!
Hopefully this will work for others. LMK if you need the version of the KPG-D1N I am on (just got it Monday), in case that matters.
73s.
73s.
