KPG-D1N Version and Firmware
sraider
Wood Lake, MN
I have kpg-d1n version 2.10 I got some new nx5800 radios that have 2.31 firmware installed. Can I use my programming software with newer firmware. Not sure what the new firmware or software version is out now. If need to update programming software can I update through program, website, or do I need to go through dealer where I bought software from. Thanks for any info
kd4efm
EL98 Florida
You can ask them for the update. 2.40 is out now.
2.31 has a dmr bug in it.
Evans
Sent from my SM-G935P using Tapatalk
kd4efm
EL98 Florida
Dmr site roaming, and p25 to dmr zone change lock up.
RK3AAG
Russia
Do not use old KPG-D1 with newer firmware. It might work, but you will risk to get incompatible settings. And you will not see new menus and controls in FPU. It’s always recommended to use matching pairs of FW and SW (or FW older than FPU).
kd4efm
EL98 Florida
You're welcome.
Never mind that last post about old software, new firmware. He is not a dealer, just a novice.
The radio will not let you read unless the software is equal or greater than installed firmware.
It will read, but error out at the end and you do not see the codeplug.
Update the kpg-d1, then radio firmware, then use the newer software, read, update, then write back.
Did you get the update yet? If not, contact me directly.
RK3AAG
Russia
As always, Kenwood dealers don't know what they sell and what they deal with. I was able to read and write radio with FPU version lower than FW version. It's possible with some releases, but it's unknown for dealers, because they are all half-educated. I don't know why you call me a novice, because I am LMR professional for many years. Most likely it's just anger because Kenwood dealers know about the product less than their customers.
buddrousa
In todays market with the $89.00 DMR radios all some dealers care about is sales not service. They are to busy trying to sell radios to sit in their office and look at the dealer site 5 or 6 times a day for updates. I am not in any way taking up for these dealers just stating what they are doing. Several dealers are having trouble selling LMR systems due to cheap cellphones and coverage over a larger area.
Comms13
911 Dispatch, SAR, and Ham Radio guy!
Oregon
I have loaded software and firmware updates 2.40 succesfully, however... now i am getting these errors when trying to write something to the radio. Note: I havent touched these settings, error is new as of the software update.
Any ideas?
kd4efm
EL98 Florida
Any ideas?
Yes, need to add numbers, can't be blank on this update. 100-1000 Is good
Comms13
Oregon
This is the issue I mentioned in the message. So it doesn’t matter what number is in there if I’m using only conventional channels and 1 NXDN conventional?
Sent from my iPhone using Tapatalk Pro
kd4efm
EL98 Florida
Nah, it's all good. I had that issue, I don't use fleetsync or mdc1200, you will be okay.
I do have numbers in those, but I don't use ptt ani. Just decode. Just need to go to personality, and default the numbers.
Comms13
Oregon
Copy that! Thank you!
Comms13
Oregon
Is this a flaw in the new software? Seems like it should be allowed to be blank..
kd4efm
EL98 Florida
I can't speak for that, but know with other programs it caused the same error notice.
So basically a check point on valid info. If something is wrong, it alerts you.
n5wig
Metairie, LA
NX 5800 k2 firmware
I was wondering if anyone could help. I just purchased the KPG-D1NK and the key for DMR. I went to load the key ,but it would complete the registration. I looked further and found a text file that said it need k2.01 firmware ..my radio has 1.71 firmware. can anyone direct me as to what Ior how to fix this.
Thanks,
Respectfully,
Michael
kd4efm
EL98 Florida
Latest is 2.40, have you made contact with the person you bought it from?
You can pm me if you need to, but I am heading to bed, long dayvwith 5 site visits to rack up in North Florida
