KPIT-Pittsburgh International Airport TSA
Binger511
Pittsburgh, PA
Says in the database that KPIT's TSA is VHF p25, supposedly unencrypted. I've heard that there has been some talk of TSA going uhf for a while, but was unsure if KPIT was affected. Anyone know if TSA is still VHF P25 unencrypted?
daine1619
Washington, Pennsylvania
As of late October, 2021 KPIT TSA was P25 unencrypted. I spent several hours out in the airside terminal waiting on a team to come in from Chicago and all comms were in the clear.
IStebleton
How far out can you typically hear comms? I was out in the area for several hours a couple months ago and was unable to pick up anything from TSA
There are very few airports testing the new UHF radios. Fed Files Blog from @ChrisP has limited info on them but it does list two locations using the active frequency of 406.7375 MHz, NAC was N01C. Radio IDs were in the 839xxx range. Clear testing was heard from locations around the airport terminals. Encryption was also noted. It is listed in the NTIA documents as being paired with 415.7375 MHz for repeater use.
daine1619
I don't typically scan TSA unless I will be near/at the Airport. But when I do scan them I can hear them when I am on the Airport Property but as soon as I leave the property they disappear.
Here at KRDU you need to be in or very near the terminal. I can not hear them at the observation park about a quarter mile away.
Binger511
Pittsburgh, PA
Interesting. Do you know what kind of radios they use? I would assume APX's but if they're just phase 1 conventional, those might be overkill. XTS's might be a better solution.
daine1619
Taking as Allegheny County just purchased APXs for every Police, Fire, and EMS agency in the county for an analog system, I cant see the Federal Government buying old used EOL equipment to "Upgrade" to UHF.
harvick21
Oakdale, PA
TSA is encrypted. Occassionally one part of the convo is in the clear but 99.99% encrypted. I'm only about 2 miles from the airport as the crow flies so no issue picking them up.
ecps92
Taxachusetts
XTS is EoL [End of Life] and yes they went APX for the new UHF at the two known [reported] airports
However Phase II only applies to trunking, so yes they are P25 [no need to include Phase]
In the area where you are, this is not the case in other areas.
IStebleton
I wouldn't be surprised if they didn't use radios at all, since it's such a small airport.
Binger511
Pittsburgh, PA
Even if KLBE used radios, they probably wouldn't use them much anyway. If you lived close to Arnold Palmer it wouldn't hurt to monitor the federal frequencies anyway.
ecps92
Taxachusetts
Best time to find out is 1-2 hrs before most of your scheduled Departures and 30 mins Prior to 45 mins after your arrivals
Search 162-174, but concentrate on 168-174 and if after a period of time [could be weeks/months] you find nothing see what 406-420 brings.
But as Chris points out, many smaller airports keep them in the chargers
Usually that is due to they can SEE each other and don't need/use the radios
Looking on-line, I don't see much other than 2 Departures today
And 2 Arrivals
Happy Searching tho, and do report back what you find, as it may not be TSA
ecps92
Taxachusetts
What Freq and NAC are you hearing for KPIT? on the VHF ?
To add to what @ecps92 said, remember they will probably be low power and you will need to be close to the terminal.
IStebleton
I was flying through KPIT yesterday, and it looked like they had UHF antennas on their radios. I did not pick up any comms though.
