KPT300 v2.0 on Windows 7
Radar412
split between Berkeley Springs, WV & Wyoming
Has anyone gotten the v2.0 KPT300 to work on a Windows 7 system? I was able to install it to my old computer so that I could move my license to a newer one however it keeps giving cancellation failed when I try to perform that. I messaged Evans earlier and he replied back to me that v2.0 did require a newer operating system. The mystery seems to be if that is the case then why did it install with no problem on my old W7 system? And, if it does require a newer operating system then how is one supposed to export your existing license off an older operating system?
Radar412
A follow up to my previous question about Windows 7 & KPT300 v2.0. I had already dual partitioned my new computer to be able to run both 7 & 10 so I went ahead and installed the LMC on both sides to be able to check and it does indeed seem that the LMC will not communicate with the server on the W7 system but immediately connected when I went to the W10 side and when I manually entered my licensed key it immediately recognized it and showed the software and 0/1 (due to my license still residing on my old W7 only computer. So the question still remains, how do you get your license off a W7 system? I installed the LMC there also and it too will not communicate with the server. Or do you have to bite the bullet and just buy another wideband license?
AM909
Radio/computer geek
SoCal
You need to contact tech support. They will reset the count(s) to make the licenses available on the new machine. You'll need to provide the old and new machine IDs and the license keys you want to move, possibly with some proof of who you are (unless you're a frequent flyer :) ).
The way this was handled is "unfortunate". :(
WB5UOM
Kenwood Tech Support can help with that as they did with me
Radar412
Thanks for the replies, Evans did take care of it. And yes, I don't think Kenwood foresaw that there would be licenses remaining on Windows 7 Machines
AM909
Radio/computer geek
SoCal
I've also run into Win7 problems with both Icom and Motorola in the last two days, too.
Must be nice for these engineers to work in an environment where they always get the latest stuff and get to be oblivious to the real world, where we have to support multiple brands and generations of radios with so much software and hardware that is a pain to keep trying to move to new environments, even when it does, seemingly miraculously, work.😒
kc8ldo
I've been dealing with the same issue. I have a Win 7 Pro box. KPT-300 V2 installed and ran fine for a while on it. Added some feature license keys to several NX-1300 radios, no problems. Then POOF, it quit getting server info one day to authenticate the account. I suspect that Kenwood changed something on their end, with their server, that now detects and refuses to communicate with Win 7 machines.
As mentioned by the original poster I have it installed on a Win 10 box using the same account license. Works just fine on it.
kc8ldo
So I wonder how long they will support Win10. It's due to go EOL in 2025. They going to plug the plug on it and force everyone to spend big bucks buying new Win11 compatible hardware?
MTS2000des
5B2_BEE00 Czar
And with Microturd playing games with Win 11 now essentially blocking all workarounds for TPM, forcing new hardware procurement, there will be even more perfectly usable, serviceable and capable enterprise grade machines n the E-waste pile soon.
wd8chl
As many issues as Win11 has had with compatibility with hardware, we are staying away from it here. And since the history of uSoft OS'es is that every other one is crap, since 11 is crap (8 was crap, Vista was crap, etc), I expect whatever is next (guessing win12?) will be better. We'll wait for that.
dropkick
This problem stems from the removal of TLS 1.0/1.1 support on the Kenwood server, as it is now only accepting TLS 1.2 and 1.3. While Windows 7 supports TLS 1.2, it does not support the cipher suites that their server is configured for (TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 or TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256). Thus Win7 is dead in the water with V2.
Might try to image this laptop and do an in place upgrade to W10, just to deactivate and move the license. Otherwise... glad to hear tech support is responsive to this. Plenty of radio techs out there with "old" laptops and "old" software, often not by choice.
