hundley206
- Joined
- Feb 17, 2007
- Messages
- 28
Can someone tell me a simple way to program KSP post 7 into my PSR500? i have read the Manuel but no luck ...can i get some simple steps to program it?
thanks
thanks
Location?Can someone tell me a simple way to program KSP post 7 into my PSR500? i have read the Manuel but no luck ...can i get some simple steps to program it?
thanks
Enter the freqs as FM freqs, enter the proper NAC and you should be in business... Much easier using programming software (I recommend Don Starr's Win500)... you'll need the USB programming cable and a computer running Windoze 2000 or later.... a premium membership for rr.com will allow you to download directly to Win500 and then transfer the results to your radio....If you use a PRO96/2096 or 396T/996T you will need to enter the freqs in "FM" mode, if you have the GRE 500/600 you can enter the Network Access Code (NAC) for each freq--this will reduce "interference" from other freqs....
Programming software for whichever scanner you buy is recommended--there are good free and commercial programs available for all radios... and the appropriate cables to connect to a computer....
KSP only means one thing in the Kentucky forum. I see your in Arizona.Location?
Software?
KSP=?
