KTI-3 and KAS-10
Samo84
Lebanon
Hello
I am trying to connect my KAS-10 with KTI-3 with NX-710, I connected the KTI-3 with my repeater and gave it an IP, now i would like to use the KAS features with this, can any one help me on how doing this and what are the advantages of using KAS-10 with this interface, can i change the repeater channel or do any recording to the transmissions ?
Thanks in advance,
kd4efm
EL98 Florida
1) KTI-3, is the NXR-710 Version 2
2) KAS-10 is AVL and low budget Dispatching when hooked up to a NX-x00 (NX-700)
KAS-10 is not remote control for the NXR-710, it is only a dispatch and AVL program. NexeTALK is one of third party NXDN vendors where it can record conversations.
What is you primary goal, everyone has different goals, so myself nor MMcKenna can really give you
a true operating guide out of the cold blue.
I have played with it on the HAM NXDN network, as I can zing Icoms and kenwoods with it.. (in tests)
but for the most part, it's pretty cool for SDM and AVL, and stunning radios if your using it for SMR
reasons.
EFM
Samo84
Lebanon
Hi kd4efm
Thanks for your reply,
1st of all, i would kindly request all the operations guide you have, anything for me is and added value,
My case is as follows
I have NX-710 in a site that has two zones, Analog and digital, currently working on digital mode however i could connect from my site to this repeater and change the zone to digital any time using KPG-129
My question is:
Can i record all conversation using KAS-10, or send messages to mobiles or stun/kill whatever ?
With regards,
kd4efm
EL98 Florida
No, KAS-10 is not a vocal program. If you have the dvsi3000, you could. Just not as straight forward as I wish it was.
kd4efm
EL98 Florida
KAS-10 Brochure
Here is the brochure.
  • KAS-10.pdf
