KVL-3000 DES version load DES-XL / OFB
N1XD
Danbury CT
I bought a KVL3000 and it only has "DES" in it. My XTS5K only does DES-XL or DES-OFB will it work? I still need to buy the cable to go between, so I have not tried it yet. Thanks
MattSR
Sydney, Australia
As an aside, I would reccommend getting a hirose KVL cable and the assorted adaptors instead of getting the fixed cables. This way you can load any radio you want..
setkiam
Chile
Hello friends, I just bought a KVL-T3011D. But I have inadvertently blocked. I need to know if anyone can help me to unlock the device (reset).
Also do not use the equipment, so if I can help with instructions, much better.
Greetings to all
Eduardo
code3cowboy
CA
Ill second this, I find it quick and easy.
BORG
Greetings to all
Eduardo
With this procedure all existing keys will be lost.
Turn the unit off and then press and hold the CLR button while pressing the ON button. The KVL displays bUsy for two seconds followed by ALL ErASE?. Next press ENTER and the KVL displays bUSy for two seconds followed by ALL ErASEd.
The lock and all key variables are now erased and all group maps have been reinitialized to their default settings.
