Ky Abc
rcpriv
kentucky
For normal operations, ABC is dispatched through KSP Headquarters Radio Room using the same frequency as KVE (453.300, 162.2 PL). Not alot of traffic but thats what they use.
This should be in the database-Is it confirmed?? If so, how did you find this frequency??
mastr
453.300 is probably the easiest freq. in the state to find, it has been in use statewide since about 1980.
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
As I understand the most common method of operation, locally there will be no traffic from ABC Agents until AFTER they have made their checks/raids, etc.... then mostly they will be on local police/Sheriff freqs if they are on the radio at all. Or, as one barkeep told me after his place was cited for illegal activity, "I didn't know they were here."
What is the 453.300 frequency for?? It is listed as several different things... different KSP posts, KVE, etc.
rcpriv
kentucky
UnitCharlie is more correct. My first post should have read something like this:
Officially, ABC is dispatched through KSP Headquarters Radio Room using the same frequency as KVE (453.300, 162.2 PL). In reality, they most commonly use either cell phones and/or local agencies radio systems for their operations.
rcpriv
kentucky
No. And you won't either unless:
1. SRT is activated and;
2. You're fairly close to were the SRT is operating.
Sometimes they also use, depending on the type of operation, the post freqs in the area they are activated.
