LA County Fire Camp Crew Carrier Crash
LZJSR
California
Latest CHP CAD update on incident in Gorman, CA
2:58pm per 89-1b turning wb traffic back to 220th except for big rigs
2:54pm per pc 1097 at quail lake onr to eb 138 - will need caltrans here for hard closure also w/cones and signs
2:47pm 1039 bfd dispatch id 11671 copy entry 41
2:46pm line 40 is for ft tejon to shut down sb 5 to 138 and 138 at gorman post rd
2:46pm 78-508 advsd sb 5 to eb 138 and 138 at gorman post rd
2:46pm sigalert issued on blue
2:45pm bfd dispatch ll asking if they should shut dwn sr138 ar gorman post road?
2:43pm tmc copies sigalert 10-39 media
2:42pm issue sigalert unk duration - nb and sb 5 to 138 closed also 138 closed at av d
2:42pm 1039 bfd for line 26
2:41pm caltrans also activate signs on i-5 that 138 is closed
2:41pm bakersfield plz roll ft tejon to close sb 5 to 138
2:37pm per 89-s4 close 138 at av d jwo 14 - can poss set up signs nb/sb 14 at av d
2:37pm plz roll ft tejon unit to close sb 5 to 138
2:36pm plz roll caltrans for an extended closure per s3
2:36pm all lanes are blocked will need to shut down 138 at 5
2:33pm dupe caller advised lancaster rd at 300th st w - newhall beat )
2:30pm 1039 psdsii
2:28pm 1039 lacofd #14 they have airship enrt -- rescue #5 enrt
2:26pm dupe caller advise major injuries
2:22pm per rp fire trk o/turned -several times -no body getting out of veh or fire truck
2:19pm per rp fire trk hit a veh head on then o/turned
2:18pm 1039 lacofd hartman
2:18pm approx 10 miles jeo 5 --fire trk o/turned hit a veh head on
LZJSR
California
Final Update Crew 14-3 Crash
2 DOA (1 Inmate firefighter from Crew 14-3, and driver of vehicle which hit crew truck head on).
Multiple critical injuries, 5-6 minor injuries.
Incident: 1794 Type: Possible Fatality Location: LANCASTER JEO OLD RIDGE ROUTE RD
ThomasBrothers: 22 9G info as of: 11/23/2010 7:41:58 PM
ADDITIONAL DETAILS
7:24PM TMC COPIES SIGALERT UPDATE
7:23PM MAIT ESTIMATES CLOSURE FOR ANOTHER 2-3 HOURS
6:27PM V1 C4, TRAFFIC STOPPED, POSS 23152 VEH ALMOST HIT V1
6:25PM 1B ETA 15-20 MIN TO V1
6:23PM V1 REQ UNIT AT CLOSURE, 138 AT 300 W
6:12PM REGARDING LINE 126 -- NO CLOSURE AT 138 AT 14 -- ORIGINAL REQ FOR CLOSURE MADE AT 1437 HRS ON LINE 27 CLOSE 138 AT AV D JWO 14 -- CAN POSS SET UP SIGNS NB/SB 14 AT AV D
6:04PM PER 89-1B V1 WILL REMAIN AT 300TH ST WEST UNTIL NEWHALL CLEARS TC SCENE
6:04PM CORRECTION - THERE WERE NO CLOSURES IN PLACE FOR LINE 126
6:03PM PER 89-1B NEG ON CLOSURE AT 300TH ST W AT 138 --- ONLY CLOSURE 90TH W AT AV D
6:03PM ANY FURTHER QUESTIONS FOR LINE 126 THIS IS PER RP #3
6:02PM PER CITZ - THERE IS A CLOSURE AT 300ST W AT SR138 - TURNING TRAFFIC AROUND - MEDIA STATES WB 138 FRM 14 IS CLOSED - RP JUST TRAVELED THRU THE AREA APPROX 10 AGO - THERE WERE CLOSURES IN PLACE FRM THE 14 FWY TO 230TH ST HEADING WESTBOUND
5:55PM 89-1B IS SETTING UP CLOSURE AT 90TH ST W AT AV D - PLZ CONFIRM ETA FOR CALTRANS
5:44PM PER BAKERSFIELD, 102-52 NEEDS UNIT TO RELIEVE AT CEMENT PLANT, HAD SEVERAL VEHS ATTEMPT TO GET THRU, SEVERAL HOUSES IN AREA -- ADVSD 508 - UNIT WILL ADVS
5:37PM 78-C AND 79-S1 1097/1098 SCENE
5:34PM CALTRANS CLOSURES FOR 5 ARE TAKEN CARE OF, WILL NEED THE CLOSURE ON 138 AT 90TH W AND DIVERT TRAFFIC NB TOWARDS TEHACHAPI, THNX
5:31PM PER 78-508 WILL BE PICKING UP CLOSURE NB 5 TO EB 138, AND P2 CAN RELEASE CLOSURE QUAIL LAKE ONR TO EB 138 -- HARD CLOSURE IN PLACE AT GORMAN POST RD
5:30PM PER 78-508 IF FT TEJON UNIT MANNING SB 5 TO EB 138 - THEY CAN PICK UP THEIR CLOSURE
5:23PM PER 78-508 - ADVS S3 ASC IF OK TO OPEN UP THE EXIT TO 138, HOWEVER CALTRANS HAS HARD CLOSURE ON 138 DIVERTING TO GORMAN POST RD
5:22PM PER 78-508 AN ADD L CALTRANS IS 1097 NB 5 TO EB 138
5:21PM CALTRANS PLZ ALSO CONFIRM YOU HAVE UNITS RESP FOR THIS HARD CLOSURE NB 5 TO EB 138, SB 5 TO EB 138, QUAIL LAKE ONR TO EB 138, AND GORMAN POST RD AT SR-138 -- THIS WILL BE A LONG TERM CLOSURE FOR MAIT INVESTIGATION
5:19PM PER 89-1B WILL NEED TO START CALTRANS TO RESP TO THE 138 AT 90TH ST W AND DIVERT TRAFFIC NB TOWARDS TEHACHAPI -- CALTRANS PLZ ACKNOWLEDGE REQUEST
5:17PM PER 89-1B SR VOLUNTEERS 1097 AT 300TH ST
5:10PM PER 78-S3 THIS WILL BE CLOSED FOR SEVERAL HOURS
5:10PM PER 78-508 ONE CALTRANS EMPLOYEE 1097 AND DOES NOT THINK ANY OTHER CALTRANS RESP
4:54PM PER LA CORONERS OFFICE ADVS ETA 10 OR LESS - TALKING W/UNIT ON SCENE VIA LL/CELL PHONE
4:53PM 78-S3 ADVSD HE MADE CONTACT W/CORONER S OFFICE, THNX
4:53PM COPY LINE 82 FOR CLOSURE 138/AVE D
4:53PM 1021 LA CORONER OFFICE ASC IF UNITS/LACOFD CAN REMOVE THE BODY FROM THE VEH
4:50PM CHP 10-6 -- REQ HARD CLOSURE AT 138 AT AV D
4:47PM CT HAS NO AERIAL EQUIPMENT ALSO CT 97 AT 138/14 FOR CLOSURE AND NO CHP IN AREA
4:46PM PER 78-S3 MADE CONTACT W/CORONER S OFFICE VIA LL
4:44PM SOMAIT 7 ADVSD TO ROLL CALTRANS W/AERIAL BUCKETS FOR PHOTOS -- WILL TRY TO GET CLARIFICATION, NEG RESP ON AIR
4:37PM AIR 51 1098 W/PHOTOS, REQ UNIT AT WHITEMAN AIRPORT ETA 25 - 78-501 WILL BE ENRT
4:27PM AIR 51 IS 1097 FOR AERIAL PHOTOS
4:25PM CT ETA 30
4:19PM PLS SEE LINE #79 AND ETA
4:16PM PER 89-1B CONFIRM CALTRANS ENRT TO SHUT DOWN 138 AT AV D - ALSO ETA IF POSS, THNX
4:13PM IS THERE A COMMAND POST OR SITE SET UP FOR MEDIA?
4:06PM PER 89-3B 138 BLOCKED AT 60TH WEST - NO TRAFFIC SHOULD BE COMING THRU
3:48PM 1039 LA CORONER OFFICE CC#2010-7728, CC#2010-7729 DRVNG TIME FROM DWN LA - ADVS PLS DO NOT REMOVE VICT FROM VEH - NO CONTACT NUMBER FOR THE CORONER AT THIS TIME - THANKS
3:46PM AIR51 ENRT - ETA 45
3:18PM 1039 LA CORONER OFFICE WILL CALL BACK CC#
3:01PM 1039 5-H50
2:58PM PER 89-1B TURNING WB TRAFFIC BACK TO 220TH EXCEPT FOR BIG RIGS
2:54PM PER PC 1097 AT QUAIL LAKE ONR TO EB 138 - WILL NEED CALTRANS HERE FOR HARD CLOSURE ALSO W/CONES AND SIGNS
2:47PM 1039 BFD DISPATCH ID 11671 COPY ENTRY 41
2:46PM LINE 40 IS FOR FT TEJON TO SHUT DOWN SB 5 TO 138 AND 138 AT GORMAN POST RD
2:46PM 78-508 ADVSD SB 5 TO EB 138 AND 138 AT GORMAN POST RD
2:46PM SIGALERT ISSUED ON BLUE
2:45PM BFD DISPATCH LL ASKING IF THEY SHOULD SHUT DWN SR138 AR GORMAN POST ROAD?
2:43PM TMC COPIES SIGALERT 10-39 MEDIA
2:42PM ISSUE SIGALERT UNK DURATION - NB AND SB 5 TO 138 CLOSED ALSO 138 CLOSED AT AV D
2:42PM 1039 BFD FOR LINE 26
2:41PM CALTRANS ALSO ACTIVATE SIGNS ON I-5 THAT 138 IS CLOSED
2:41PM BAKERSFIELD PLZ ROLL FT TEJON TO CLOSE SB 5 TO 138
2:37PM PER 89-S4 CLOSE 138 AT AV D JWO 14 - CAN POSS SET UP SIGNS NB/SB 14 AT AV D
2:37PM PLZ ROLL FT TEJON UNIT TO CLOSE SB 5 TO 138
2:36PM PLZ ROLL CALTRANS FOR AN EXTENDED CLOSURE PER S3
2:36PM ALL LANES ARE BLOCKED WILL NEED TO SHUT DOWN 138 AT 5
2:33PM DUPE CALLER ADVISED LANCASTER RD AT 300TH ST W - NEWHALL BEAT )
2:30PM 1039 PSDSII
2:28PM 1039 LACOFD #14 THEY HAVE AIRSHIP ENRT -- RESCUE #5 ENRT
2:26PM DUPE CALLER ADVISE MAJOR INJURIES
2:22PM PER RP FIRE TRK O/TURNED -SEVERAL TIMES -NO BODY GETTING OUT OF VEH OR FIRE TRUCK
2:19PM PER RP FIRE TRK HIT A VEH HEAD ON THEN O/TURNED
2:18PM 1039 LACOFD HARTMAN
2:18PM APPROX 10 MILES JEO 5 --FIRE TRK O/TURNED HIT A VEH HEAD ON
RESPONDING OFFICERS STATUS
2:45PM CHP Unit On Scene
4:35PM CHP Unit On Scene
5:47PM CHP Unit On Scene
5:54PM CHP Unit Enroute
5:54PM CHP Unit On Scene
6:43PM CHP Unit On Scene
6:44PM CHP Unit On Scene
6:53PM CHP Unit On Scene
7:14PM CHP Unit On Scene
7:31PM CHP Unit On Scene
