La Guardia Airport
newsnick175
Denver, North Carolina
PAPD LAG comms are hot on the PA TRS. Not only testing, but normal dispatch. Have to check-out if they are simulcasting with the UHF, or completly switched over.
CqDx
US
Few months ago I heard PAPD radio techs doing coverage tests in the vicinity of LGA, this could possibly be related.
usnasa yes you will pick them up with the 2055 make a bank set it to edacs then chan number 01 not 00 but 01 is where you start programming the lcn freqs.
program in this order
01 851.21250
02 851.81250
03 852.37500
04 853.60000
05 852.87500
06 853.55000
07 853.91250
usnasa
Brooklyn NY
ok really thank you i will try it also should you program all the freq or just the primary control channels ?
CqDx
US
You need all the channels, just enter them in order by the LCN number.
usnasa
Brooklyn NY
ok understood thanks i did the channels like xeno194 told me to do and im still not hearing anything any help would be great thanks to all
i dont know how many banks your radio has but set an empty one just for the nynj pa
so im going to assume you have 10 banks 0-9
Setup bank 9 for edacs
then put all the freq in each bank starting at channel #1 not chaneel #0 (0 is usally the first channel for each bank) so skip 0 and use 1 then 2 then 3 then 4 etc etc etc. next make sure you set each chan for edacs and you should be ok.
are you doing this by hand or with a pc editor
usnasa
Brooklyn NY
i have nine banks total this is what i have i am hearing jfk trunking but not bust at all
bank 0 ch 01 primary
bank 1 ch 01 wtc
bank 2 ch 01 jfk
bank 4 ch 01 Holland Tunnel
all set to edacs i am programing it with win 97
i also have conv freg in the same bank do i need to skip a line between edacs and conv freq ?
you only need to use the primary so use the freq from primary
empty out bank 1 2 and 4 of your scanner
also do not put any other freq in bank 0 so it will be dedicated to nynjpa
sorry if im confusing you
so bank 0 set to edacs
these freq starting at channel 1
01 851.21250
02 851.81250
03 852.37500
04 853.60000
05 852.87500
06 853.55000
07 853.91250
in that order. make sure you dont enter 01 and 02 and 03 before the freq
then set each freq for edacs
worst comes to worst i can remote into your pc and do it for you
let me know
usnasa
Brooklyn NY
sorry this is what i have currently
bank 1 ch 01 wtc
bank 2 ch 01 jfk
bank 3 ch 01 Holland Tunnel
but what about the wtc, jfk , holland tunnel
and what about all the talk groups ? im sorry to be a pain but i was asked to do it this way ? i was getting some traffic but not very much at all
your not a pain
just use the primary
all your talkgroups are fine
anyone else want to chim in?
and help
usnasa
Brooklyn NY
thanks u only have primary and your getting everything ? and u dont use the other channels i really dont know
go download teamviewer and email me when is a good day and time to connect to your pc and i will remote in and fix it for you.
