LA/OC Military Air
CharlesDom
If you live in the LA County area, do you pick up any FM/AM military air activity? If so what are some good frequencies? I'm a little east of LA and haven't been able to pick up much except for on HF. I do have a good outdoor antenna so my setup is capable of monitoring them.
Thanks for your response.
gcgrotz
Savannah, GA
Thanks Mick, I'm going to be out there next month and I was wondering the same thing. Will be at the Marriot in Cyprus which I see is literally right off the end of the runway at some military airfield.
Gotta get started loading the '396!
Markb
Planet Earth
That would be Los Alamitos Army Airfield (KSLI). Airnav.com has a pretty good list for them. They are pretty quiet for the most part. A lot of civil helos and NG Blackhawks doing pattern and PAR work, but an occasional surprise is not out of the question.......
Mick
Western U.S.
Courtyard by Marriott® Cypress/Orange County
5865 Katella Avenue Cypress, California 90630
It's at the east end of the Los Alamitos Airfield.
Joint Forces Training Base
4442 Doolittle Avenue
Los Alamitos, CA. 90720
143.0625R 79.7 "Base Ops"
143.2125R 173.8 Misc. “Tower WX Maint.”
143.5875R 94.8 Fire Dept.
143.7125R 103.5 Security
143.7375R 127.3 Maint.
Here's the current (June 2008) info from http://www.airnav.com/airport/KSLI:
ATIS: 118.875 379.975
LOS ALAMITOS GROUND: 126.95 257.95
LOS ALAMITOS TOWER: 123.85 251.15
SOCAL APPROACH: 124.65
SOCAL DEPARTURE: 124.65
AFLD OPS ADVSY SVC: 126.2 237.2
ARNG AASF: 233.8 41.5
EMERG: 243.0
RDR: 124.75 127.95 230.8 231.0 234.1
USAR OPS: 139.05 230.9
