Cal-Fire Incident Command team 6 has been requested and activated for this incident.
Enroute from So. Ops.
Multiple Strike Teams Requested.
LAC is the three letter designator for the LA County Fire Department and LFD for the L.A. City Fire Department. I thought the Porter Ranch area was in LFD jurisdiction.
I'm picking up, between the lines, and by looking at federal interagency dispatch center CAD's, that some incident management teams and other fire apparatus/crews had been prepositioned at South Ops and on the four southern California National Forests.
It's no surprise that this has blown up so quickly, and maybe the Angel Island fire, as well.
Dry air has increased the fire danger all around the state. We're in what I've taken to calling the October transition: high fire danger during the day, including red flag warnings, and frost advisories at night.
Command: 159.15
Air To Grnd: 161.52
For those of you who have Google Earth, I found the fire periemters in ESRI shapefile format for both the Sesnon and Marek fires. I converted them to KML for Google Earth if you'd like to see where the fires are. You need to change the file extension from txt to kml once you download the attached file and then open it in Googe Earth.
The file was time stamped last night at 9:55 so the fires are likely a bit larger now.
Command: 159.15
Tac: 155.325
Branch IV Tac: 154.265
Air To Grnd: 161.52
LACoFD Logs: 470.4375
LAFD Tac: 858.7625 (162.2)
LAFD Command: 860.4375 (186.2)
Air Attack: 134.975 and 135.975
VCSO Company: 129.95
VCFD Tactical: 153.95
VCFD Command: 154.325
Staging at Conejo Creek Park (Janss Rd east of SR-23, Thousand Oaks)
A comm unit leader I spoke with on a fire up here in August said that unused railroad frequencies were part of the pool of frequencies that could be used on large incidents. Each comm unit leader is issued a CD each year showing all the unallocated federal and railroad frequencies that can be assigned on incidents for tactical, air to air, and air to ground use. I hadn't heard of railroad frequencies being included until I heard it from him.
Not sure why 161.52 was being used, but I heard it all day from my home. Also, I just heard Angeles advise the new Lead Plan that the new Air Tactics Frequency is 171.1375 and the new Air to Air frequency is 134.875.
