Laclede County Radio System
Gmod12
Springfield Mo
Recently moved to Laclede County. I've noticed both the county and city of Lebanon have TGs in the MOSWIN system. Afterr 3 weeks, I've heard nothing. On an off chance that they are still using their old conventional systems, I plugged those freqs in as well and still nothing. Are they using something other than whats listed in the database?
dispatch235
Central Missouri
I also have both the HP-1 and HP-2 and live about 40 miles north of Laclede Co. and usually copy them on MOSWIN really well. Since I use both of them at home I don't use the location control, ie no zip code input, and under edit favorite list for all my areas I always put the range
in as 200 miles so it doesn't skip over any towers I want to hear in the distance, otherwise I've found out it will skip them even if I don't use location control...there is a thread about that somewhere here on RR.
Also I only use the 4 nearest towers around me and delete all the extra sites that it imports
82623
82624
tvengr
Well Known Member
Baltimore County, MD
Here is a favorites list for Lacrede Co MO. This is just the MOSWIN trunked system and does not include conventional frequencies. Save the attached file to your computer and extract. Go to the File tab in Sentinel and Import from hpe file. Select New Favorites List, name it Lacrede Co MO, and click OK. Locate and highlight the extracted file (Lacrede Co MO.hpe) and click on Open. You should see it appear as a favorites list.
  • Laclede Co MO.zip
scanman1958
St. Louis
I am in Laclede/Dallas county right now and hear both Laclede Co sheriff and Lebanon PD on MOSWIN. Also hearing Troop D, I and A. Hearing some other stuff too but not paying too closely to what's going on.
