LACoFD
tkenny53
socal
I have noticed dispatching using 154.28, State White 1, is that LA City using that? Usually on brush fires, which have been around the 5 and the 405 area this week.
A general command for equipment, It is hard to hear from OC.
K6CDO
Hanover Co. VA
154.280 is VFIRE28, and is designated by the State as a dispatch contact / alternate (to CESRS) Strike Team en route channel. If it is being used in the 5 / 405 area (I am presuming you mean at the north end in the San Fernando Valley), then it would be appropriate that it is not well heard in Orange County.
Markb
Planet Earth
It's actually VFIRE21, but you already know that ;)
Many, if not most fire agencies in the area will make a notification broadcast if there is a report of a fire within one of the mutual threat zones (SOLAR, PROS and whatever they call the one up that way, I don't recall).
Sent from my SM-G935V using Tapatalk
loomup
Los Angeles
VFIRE21 154.2800 may be utilized by fire department resources (including Strike Teams) to contact a fire dispatch center:
• when outside of their normal response area
• for dispatch center-to-center contact
• Announcements of special weather alerts or other emergency related information is acceptable.
VFIRE21 can be used as the initial contact channel for resources reporting to a staging area. Upon arrival, strike teams will be advised of which channel to listen to for assignment.
The VFIRE channels shall not be utilized as a travel channel. The only acceptable VHF channel to be utilized statewide as a travel channel is the California Emergency Services Radio System (CESRS) channel, 153.7550 MHz
Dispatch centers are prohibited from dispatching their own resources on VFIRE21 when their dispatch center suffers a communication failure.
Onscene tactical operations shall not be coordinated on VFIRE21.
Announcements of a non-emergency nature (e.g. funerals, drills, etc.) are prohibited.
http://www.caloes.ca.gov/FireRescueSite/Documents/CalOES-Operations Bulletin 28.pdf
Sent from my iPad using Tapatalk
allend
Long Beach, CA
COMMAND CDF C1 IC & OPS 151.3550 Tone 8 103.5 159.3000 OST N H A T-1 Santiago Pk, T-5 Strawberry Pk
COMMAND CDF C2 IC & OPS 151.2650 Tone 8 103.5 159.3300 OST N H A T-1 Santiago Pk, T-5 Strawberry Pk
COMMAND CDF C3 IC & OPS 151.3400 Tone 8 103.5 159.3450 OST N H A T-2 Carbon Cyn, T-4 Sierra Pk, T-5 Strawberry Pk
COMMAND FS CNF IC & OPS 172.2750 Tone 8 103.5 166.2500 OST N H A T-1 - Sierra Pk, T2 - Santiago Pk, T-12 Sitton Pk
COMMAND FIRE OC IC & OPS 151.0100 Tone 2 123.0 154.9650 Tone 2 123.0 N H A
COMMAND LAC V-1 IC & OPS 152.1500 Tone 14 151.4 158.6100 Tone 14 151.4 N H A
COMMAND RRU 2 IC & OPS 151.1750 Tone 1 110.9 159.2850 OST N H A T-1 Santiago Pk, T-9 El Cariso
TACTICAL VFIRE22 DIVS/GRP 154.2650 Tone 6 156.7 154.2650 Tone 6 156.7 N L A
TACTICAL VFIRE23 DIVS/GRP 154.2950 Tone 6 156.7 154.2950 Tone 6 156.7 N L A
TACTICAL VFIRE24 DIVS/GRP 154.2725 Tone 6 156.7 154.2725 Tone 6 156.7 N L A
TACTICAL VFIRE25 DIVS/GRP 154.2875 Tone 6 156.7 154.2875 Tone 6 156.7 N L A
TACTICAL VFIRE26 DIVS/GRP 154.3025 Tone 6 156.7 154.3025 Tone 6 156.7 N L A
TACTICAL VTAC11 DIVS/GRP 151.1375 Tone 6 156.7 151.1375 Tone 6 156.7 N L A
AIR-to-GROUND LAC A/G ALL PERSONNEL 154.4000 Tone 14 151.4 154.4000 Tone 14 151.4 N H A TBD @ TIME OF DISP
AIR-to-GROUND CDF A/G ALL PERSONNEL 151.2200 CSQ 151.2200 CSQ N L A TBD @ TIME OF DISP
EMERGENCY AIR GUARD ALL PERSONNEL 168.6250 CSQ 168.6250 Tone 1 110.9 N L A EMERGENCY USE ONLY
