Laird WPC39S0B-001 does not fit NMO mount
cmaness2001
Los Angeles, CA
Its not the NMO roof mount, its the underside stiffing plate you put in to take the strain off the roof sheet metal. I would go at least 6" X 6" or larger of a moderate thickness sheet metal like 16 or 14ga, whatever will add to the thickness of the vehicle sheet metal and still allow the NMO mount to work. I would also bond the extra sheet metal to the underside of the roof with epoxy or heat resistant glue.
Well, I guess no cheap whip and spring for me.
Yeah, sorry. But thanks for your help!
mrweather
Then a good yank folded the whole thing and it came right out. The aluminum threads are intact!
Aluminum threads? Makes me wonder if there some sort of galvanic corrosion going on that caused the NMO mount ring to get stuck. All my Larsen NMO coils have brass threads.
prcguy
Aluminum and brass, bad combination to be together outdoors. Its a good idea to goop up the NMO threads with silicone grease or even a commercial dissimilar metal lube like Burndy Penetrox in situations like this.
