I'm using SDR# with (2) V5 Nooelec dongles. I put a bank together from the database and what folks are posting in the Arizona thread.
Someone over there mentioned I should be in NFM for VHF, and AM for UHF. I added a few of the same VHF entries but switched to NFM, so I'm scanning both.
99% if my issue is 8 miles distant and an antenna height of 15ft. I know I can get GA/CA when they are in the air from Sky Harbor (15 miles away) and with the gain all the way up, ground transmission from the tower barely.
Anyways, if someone feels like shining some light on what I'm probably doing wrong - I'd me most appreciative.
PS: I've also tried the trunk system that the data base shows on SDRTrunk. I can't even get the control channels to come up - just "idle'. All my other aliases work fine.
