Lakewood, nj
kc2wtj
Brick,NJ
I live in Manchester twp not far from lakewood, I'm not get them at all. Is anyone not hearing lakewood, if someone does hear them what are your settings? Please help
kc2wtj
Brick,NJ
It does help that I'm using the stock antenna also, so could that be my issue also?
RandyKuff
Lorain, Ohio
And may I suggest more info...
Like what radio are you using...
The more info you give makes it better for you to get an answer...
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Word of advice to the OP: Any time you see an uppercase "E" anywhere in the mode column, this means full Encryption as denoted in bold red below. A lowercase "e" would indicate partial encryption but there's no example of that here. In the event a trunked system is involved encrypted talkgroups would read "DE" or "TE" where in comparison "D" and "T" without an upper or lowercase "E" would indicate a "clear" talkgroup. Hope this makes sense
Lakewood​
FrequencyInputLicenseTypeToneAlpha TagDescriptionModeTag
453.325458.325WPAC577RM398 NACLkwd PD 1Police Ch. 1 DispatchP25ELaw Dispatch
453.600458.600KAR824RM398 NACLkwd PD 2Police Ch. 2P25Law Tac
453.200458.200WPLX241RM398 NACLkwd PD 3Police Ch. 3P25ELaw Talk
453.800458.800WPGW539RM398 NACLkwd PD 4DPolice Ch. 4D/OEMP25Multi-Talk
453.800458.800WPGW539RM127.3 PLLkwd PD 4APolice Ch. 4A/OEMFMNMulti-Talk
453.125458.125WPMA452RM398 NACLkwd FDFire DispatchP25Fire Dispatch
453.650458.650WPAC577RM398 NACLkwd EMSEMSP25EMS Dispatch
155.055WPAC577BMLkwd EMEmergency ManagementFMNEmergency Ops
45.120WPAC577BM664 DPLLkwd DPWPublic WorksFMPublic Works
453.400458.400RM107.2 PLLkwd HAHousing AuthorityFMNPublic Works
471.7375474.7375WQV867RMLkwd MUAMunicipal Utilities AuthorityFMNPublic Works
kc2wtj
Brick,NJ
Lakewood​
I'm talking about there ems and fire dept I don't hear them at all and I like in manchester
Whiskey3JMC
Philly burbs 🇺🇸
Are the applicable service types turned on? (see "Tag" column in table I provided in Post #6) Also ensure the channels aren't avoided. If fire & EMS are only putting out the 20 to 25 watts they're licensed for then you may need an antenna upgrade from 15 to 16 miles out if no joy using stock while outdoors pointing antenna in Lakewood's direction. Also set your squelch to 2
cash082
Wall Township, NJ
Hear lakewood FD all over, was hearing them almost to the Driscoll Bridge today. They have a fine signal. Make sure you are using a P25 (digital) scanner/receiver.
policefreak
Berlin, NJ
I was using a Relm KNG p400 radio, but I was able to get both Lakewood Fire and EMS as Rt 70 WB by the Wawa at Rt 530. The next time I heard traffic I was 70 WB at the Burlington County line and EMS had difficulty coming in due to the topography.
