Slated for Dec 31, 2020, Lancaster county will no longer be paging on low band two tone pagers. Paging is expected to become part of the county wide p25 system. Updates to follow.
33 MHz will no longer have LCWC Fire/EMS traffic..... They will all go silent.
It'll be just like York County...
Gotcha. I'm going through the same thing in Luzerne county. The old men think digital means encrypted...Er,
Was simply referring to what a casual (dare say average) scanner user will observe. Look at York Co RRDB page, Lancaster will be very similar. No more 33 MHz. There are MANY scanner users in the Lanco area who have not upgraded their scanners, They will be crying foul when they no longer hear anything.... They don't come here.. They don't even know this place exists... they don't know what pager tones are either (P25 or otherwise)
All they'll know is their radio is silent.. There have been recent posts over in the York forums asking where the conventional stuff went.. That was the simple extent of what I was trying to say...
I'm not trolling or breaking balls, but am genuinely curious why you consider talkgroup voice dispatch the "correct" way. I assume you're referring to the original method the Unication pagers required, which was a dedicated talkgroup for each agency/alert? Or are you talking about conventional P25 vs trunking?...either two tone over P25 or the correct way of talkgroup voice dispatch.
It is true that the tones vary somewhat between analog and P25. That's actually done on purpose, as the tone frequencies are "standardized" by the DVSI vocoder. In fact, they actually differ between FDMA and TDMA as well, with TDMA offering more available tones than FDMA (better AMBE+2 vocoder). If you have APX CPS, check out the help file for Tone Signaling, it shows the charts for FDMA and TDMA and how a range of Hz are standardized to one tone when encoding/decoding over P25.
From a system admin point of view, provisioning a talkgroup per agency or alert is grossly inefficient. Not so much that a modern P25 system can't handle hundreds or thousands of talkgroups, but more from the perspective of setting up console paging resources. And, of course, if you want to setup scan lists in your radios to monitor pages for various agencies, you may quickly run out of room in your scan lists.
Believe it or not, but the Tone Signaling option in the APX is very robust and pretty awesome. We got some agencies using it on our TDMA system, and there have been no complaints of missed pages aside from the occasional miss that could occur over analog. I suspect that the Unication are just as robust. The nice thing about the range of Hz getting standardized over P25 is that there's actually a bit more leeway if there's a bit of distortion in the tones.
It's also worth mentioning that obviously the radio encoding the tones should be of good quality, preferably a system console. Otherwise you wind up with garbage in = garbage out.
I'll get the help file myself but I'd like to hear your tones..If you can't find the tone charts in CPS let me know and I'll post them here. I can also post some sound clips of tones being transmitted over TDMA trunking. They are encoded by the MCC 7500 system consoles, and recorded over the air using an APX. I think you'll agree that they sound pretty good, very little warbling or distortion.
My understanding of P25 pagers was that it used astro signaling / select call until a few weeks ago when I saw a Unication set up with a specific talkgroup. I would have to think sending a call to a specific RID would be endlessly more efficient than the talkgroup method.Did unication ever change the p25 pagers to allow paging via call alert (ie using the radio id of your base station for your dept) vs needing a seperate alert talkgroup for each dept. That would never work for my county as we have at least 100 vol fire depts.
Here ya go, QCII test recorded on the 6th. No editing done to the original recording except to crop it down.
Vocaroo | Voice message
