Lansing, IL PD has been silent
Opossum214
Lansing PD has been silent for the past couple of days on the conventional channel of 155.610 which they have used for a very long time. Does anyone know if they switched to a new system or what has changed?
Opossum214
werinshades
Chicago , IL
From the Database:
Lansing​
- The emission code for the 860.7375 repeater has been changed to P25 - now a voice repeater? (5/22)
- The 155.610 Lansing PD repeater is also now licensed for P25.
Will have to change your programming Audio Type to Digital.
kevino
Database Administrator
Chicagoland
From the article:
"According to LPD Supervisor of Communications and Records Brian Weis, Lansing and Calumet City are the only two municipalities in the area that have not already converted their systems to digital."
Any word on whether or not Calumet City PD is still dispatched on their legacy 800 MHz analog repeater?
werinshades
Chicago , IL
From the article:
Might have to make a trip to Gayetys to find out :unsure: .
ILjim
Wilmette, IL
Has anyone ever found the TG that's (reportedly) used by Lansing PD? The DB shows them using SC21 (Cook County Sheriff's node?). I went through Calumet City and Dolton last weekend and didn't hear or receive anything on either VHF or 800 MHz.
thepakrat
south sub
Cal city is still using 800 mhz. I would like to know the TG for lansing if anyone knows it
ILjim
Wilmette, IL
Yes, Calumet City PD is indeed still using analog 800 MHz and was fairly active when I was there. I was referring to the frequencies that are licensed for Lansing. Even if we do find their TG, it's ENC as the attached articles state would happen.
Napalm
Lake Co, Ind
I heard 155.610 active just now (March 30 2024 1530) with P25 but didn't get the 8600 on it in time.
Napalm
Lake Co, Ind
What's 8600?
Icom IC-R8600
I am using my Pro-2006 with an Optoscan OS456 and Probe to run searches of 1MHz chunks of spectrum and leaving it going for days at a time. I'm now slowly going through what it found. 155.610 popped up with obvious P25 data but I couldn't get the Icom tuned in in time to demodulate it.
werinshades
Chicago , IL
Icom IC-R8600
Ok
