LAPD pro96?
mfmargetis
Maryland
Can the LAPD be programmed in the pro96? I don't see an "APCO 25" mode option when entering frequencies and that's the mode RR database says LAPD is.
-Mike M.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Yes it can just put all the frequencies into fm mode and dg= digital will pop up when they transmit for apco-25 :wink:
whooey
Gainesville, FL
If it is motorolla you have to enter the trunking CC's under MO not FM, the scanner will diiferentuate conventional from digital by itself. This is assuming that it is mtorolla and a trunking system. Dont know a thing about LA.
