speedway_navigator
We tested a Zetron max laptop on a wifi connection and it sounded OK. When we switched to a cat 5 cable the audio was noticeably better. Have you guys seen this?
When we went to the backup site for dispatching it took over 20 minutes for the IT guy and engineer at the 2 way shop to work through firewall issues to get the laptop working.
We also found out the fiber backup system has a similar issue, the county uses microwave from the ECC to the 2 sites. It had some rain fades and we found out the system failed over to fiber but did not realize the fiber path wasn't there.
Our goal is to make fiber primary and fail to microwave.
How do you guys monitor when your primary link fails and do you stay on the backup for a specific time period or do you switch back to primary after you determine the path is solid again?
