Been monitoring LLC 154.235 locally for many years. Recently I stopped receiving a tone for fire dispatch calls. Did something change? Using Uniden BCT8 and BCD996XT radios. Thanks in advanced.
Frank
Frank
I was hearing the tone out until recently but something has changed. Thanks for the info.Your 996XT should hear the tone out if you have the will Co system programmed in , its aP25 scanner , mine works great ,....
Were you able to find a solution to this problem? I am having the same issue. Did you end up getting the new scanner?I was hearing the tone out until recently but something has changed. Thanks for the info.
Been real busy with work and haven’t done anything yet. Makes no sense.Were you able to find a solution to this problem? I am having the same issue. Did you end up getting the new scanner?
I am just learning all of this...but with lots of research and the light bulb clicking on from RoninJoliet's posts above, I found all of the dispatch calls are broadcast now on Talk Groups (instead of the regular LCC frequency we are used to). So you will have to program in Talk Group 20122 to hear Fire East dispatch/tones and Talk Group 20121 for Fire West. It sounds like the scanner you have is the same as Ron's, so it should be capable of programming Talk Groups in addition to frequencies. My scanner did not have that option, so I was completely clueless that was even a thing. I just ordered a better model and am excited to try it out. In the meantime, you can also listen to the Talk Group thru the Broadcastify website:Been real busy with work and haven’t done anything yet. Makes no sense.
Appreciate the leg work. I need to get my computer updated so I can use free scan again.I am just learning all of this...but with lots of research and the light bulb clicking on from RoninJoliet's posts above, I found all of the dispatch calls are broadcast now on Talk Groups (instead of the regular LCC frequency we are used to). So you will have to program in Talk Group 20122 to hear Fire East dispatch/tones and Talk Group 20121 for Fire West. It sounds like the scanner you have is the same as Ron's, so it should be capable of programming Talk Groups in addition to frequencies. My scanner did not have that option, so I was completely clueless that was even a thing. I just ordered a better model and am excited to try it out. In the meantime, you can also listen to the Talk Group thru the Broadcastify website:
Hope this helps! (and hope all that was accurate as I'm learning, too!)
Up and monitoring the Will County P25 system and LCC East using the BCD996XT. Thanks Ron for your help!Your 996XT should hear the tone out if you have the will Co system programmed in , its aP25 scanner , mine works great ,....
