I have one sitting in the garage, I'll try to get some photos later. Not sure if I have a photo of it on my old truck.
I've had the same NMO-27 for probably close to 30 years now. I've used it on multiple trucks. It's been off road, hit low branches, been through parking garages. No issues. The whip is pretty flexible.
Larsen has been making professional antennas for a long time. It's what they do. They are not a hobby/scanner/amateur antenna. They are made by a company that has a reputation of making antennas for public safety use. With a minor amount of maintenance, it'll outlast your truck and probably the 4 or 5 trucks that come after that. If something happens to it, you can buy replacement parts. You can buy replacement whips. If you want, you can install a spring on the base. If the coil has an issue, you just replace the coil.
Nice thing about NMO mounts, is that you can mount dang near any antenna you want from CB band on up into the 5GHz range if you use the right mount. If your needs change down the road, you keep the NMO mount and just buy a new antenna. No swapping out mounts needed. No gimmicks, no Chinese crap antennas, no hobby grade stuff.
I've always used them mounted on the roof of the trucks I've owned. With proper installation and tuning, it'll work. I was never into "talking skip", just used it for local use. It always did fine.
Last time I tested it, I put it on my antenna analyzer from work. Here's the plot:
Channel 1 was 1.31:1 for the SWR.
Channel 19 was 1.07:1
Channel 40 was 1.35:1
As PRC Guy said, the Laird would be a better choice if you planned on using it for 10 meter band. The Larsen isn't going to give you a low SWR across that much spectrum. Here's a wider look at the above plot:
The bandwidth is too narrow for CB and other uses. But for just CB it'll be fine. The longer whip on the Laird might be a benefit, maybe a slightly different radiation pattern giving you slightly more gain, but it adds length. If the longer length isn't an issue, it might be a good choice. I was always happy with the Larsen, so never felt the need to try anything else. After cranking through all the Radio Shack CB antennas and the like, when I got to the Larsen, I was sold.
