I've been looking for a good tri-band base antenna for 150/450/800 use.
After searching all the threads there doesn't seem to be anything noteworthy mentioned , at least that has decent 800 reception included.
I use a Larsen tri-band in the car and it works great so I'm thinking about trying to modify one of these for base use.
I'm thinking about mounting the antenna on a 16" pizza pan as a ground plane using LMR-400 cable. (The total cable run is about 75 feet)
I can either solder the cable directly to the NMO mount or use a conversion kit and go with an SO-259 connector. Do any of you antenna engineer types have any opinions on which would work best? I know it's better to use an N connector for applications above 512 mhz but this isn't an option so I'm not sure which method would be better in this case.
This sounds kind of bizzare but me and a friend used a pizza pan to mount a similar tri-band (40/150/450) about thirty years ago and it worked really well. The only difference was that we used a pole mounted amplifier on it also.
Mike
Mike
