Las Cruces EDACS/P25
RobDLG
USA
Mesilla Fire has used non-encrypted talkgroups in the past, but it seems like ages since I've heard them on the air.
I posted that earlier this month, then this morning, Sunday, June 28, I hear on DTRS: "Mesilla Fire, Mesilla Fire. Training only. Training only." That was an hour ago, and it's still ongoing.
RobDLG
USA
Police EDACS channels were used to coordinate the 2026 Las Cruces Electric Light Parade. The radio traffic was EDACS-only, though; the calls did not appear on the P25 system.
It sounded like LCPD Event 1 (330/02-092) was referred to as "Channel 10", and there was a reference to "Channel 11" to be used by parade judges. Channel 11 wound up not working, though.
I was reminded of something I heard on DTRS around two years ago. It went something like: "We'll use Channel Eleven. That's available" which was almost immediately followed by "I don't want to be 'That Guy', but our radios only go up to ten".
RobDLG
USA
Yes, there are occasional problems with channel 1, so dispatch will announce that channel 2 will be used for channel 1 calls.
LCPD Channel 1, Central Dispatch, 353/02-121, has been effectively missing from the EDACS system for a week now.
Sometime after 8:30pm on Sunday, July 5, Channel 1 just plain stopped working, so Central Dispatch switched to "Channel 3". During the switch, a "gateway" was mentioned, so that answers my question regarding whether or not one was in use. Radio Shop tests were on the air shortly thereafter. (Nothing like getting called in to work Sunday night on a holiday weekend!)
On Monday morning, dispatch was still on Channel 3, so I fired up an instance of dsd-fme to start logging EDACS calls. Channel 1 was restored to the P25 system shortly after 12pm, but not to EDACS. Since then, fewer than two dozen Channel 1 calls have appeared in the logs, and I suspect those were all Radio Shop tests. Other LCPD Talkgroups were logged as usual.
SDRTrunk continues to pick up new P25 talkgroups, but nothing that wasn't already in the database for EDACS.
Chucky46
Las Cruces
After many years of listening to LCPD on EDACS, I gave in and loaded the P25 into my BCD325P2 and and found all three active channels in use. The volume for the P25 is majorly higher than the EDACS volume. Can't explain that. Channel 2 and 3 still multi-transmitting on EDACS. Don't know how long that will last. I was glad to hear channel 1 again.
RobDLG
USA
Yes, SDRTrunk is still showing the "PATROL-2" EDACS gateway alias (or whatever it's called). There are LCPD personnel who use Channel 2 almost exclusively: Animal Control Officers, Codes Officers, Park Rangers, Service Aides, (there may be others) and I take it this means the P25 radios haven't fully rolled out to this group.
There is also the Fleet Call on Talkgroup 11352, but it's not in the database. The alias appears as "-PATROL-", or "-PATROL" with the last character missing, which is apparently a thing on Harris systems.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The City of Las Cruces is still using both EDACS and P25. SDRTrunk has never identified any patches on P25, which leads me to wonder if a migration gateway (which I learned about in these forums) is in use.
The P25 system appears to be L3Harris, so I'd almost wager a month's wages that is exactly what they are using.
RobDLG
USA
There was a drastic decrease in the number of LCPD EDACS calls logged by dsd-fme, starting around 8:17am on Wednesday, July 29.
It's obviously too early to tell if this decrease is significant. Fleet Calls, such as shift change announcements, are still used on a regular basis, and still appear on both EDACS and P25.
Chucky46
Las Cruces
I no longer hear EDACS for LCPD, but all the other channels on P25 are now active. 1,2,3, 5 are active.
abqscan
DataBase Administrator
Moderator
AOA
Las Cruces is moving towards sun setting their EDACS system and purchased a Harris P25 system to replace it.
Giddyuptd
Here and there
The in house radio shop had a good run keeping the edacs alive and had got spare parts and equipment I recall back in day. Id imagine the same is being done for the harris system.
RobDLG
USA
EDACS is still going, though the active channels seem to be almost all Las Cruces Utilities.
One talkgroup I haven't heard in months, though, is 471/03-107, referred to on-air as "the landfill channel". I believe these radios were in use at the Corralitos Regional Landfill, based on constant updates regarding walking floor trucks, and references to disposal of dead livestock.
Now I'm wondering if the landfill switched to a county talkgroup on DTRS, and I just can't hear it. The landfill is located close to the SNMCF Site, so the radios may not even affiliate with the A Mountain Site I monitor. Aiden Hills might even be closer to the landfill than A Mountain.
I guess I could always drive out there with a scanner.
Giddyuptd
Here and there
It wouldn't surprise me if they are encrypted as the county road shop is encrypted.
RobDLG
USA
Agreed! Of course, I should still see the talkgroup ID pop up on SDRTrunk if their radios affiliate, though.
County roads was unencrypted for at least several days recently. I heard at least one crack about "$5,000 radios".
RobDLG
USA
So it turns out that SDRTrunk and dsd-neo display the alias, but trunk-recorder 5.2.1 does not!
In the trunk-recorder logs, the "tag_ota" field is an empty string for calls from EDACS radios, which appear on the P25 system with a Unit ID that begins with "9970". However, the field appears to be properly populated when calls from P25 radios are logged.
RobDLG
USA
After further review, I've concluded that trunk-recorder 5.2.1 is indeed incapable of comprehensively logging the Las Cruces P25 system.
The issue is that trunk-recorder fails to decode certain verbose and informative over-the-air (OTA) aliases.
The Harris OTA decoding capability was recently added to trunk-recorder, and the pull request indicates the process is not as straightforward as one might think.
(Full disclosure: While reviewing the source code, I got distracted by the 300ms "magic number" and felt compelled to test increasing the value. I checked 380ms and 450ms, but the missing aliases did not appear, and I'm not even sure they should have.)
Nevertheless, SDRTrunk, dsd-neo, and the latest version of dsd-fme do indeed display the Harris OTA aliases. As a result, I'm currently using dsd-fme to supplement the trunk-recorder logs.
The simultaneous use of EDACS and P25 appears to trigger a bug in trunk-recorder, one that is unlikely be resolved prior to EDACS retirement on this system.
