There you go. The final answer has been spoken from the horses mouth.
END TO END. This is new normal in Southern California now and forever.
The current 480 system LASD uses in analog mode performs poorly in a lot of the Angeles Forest, which was to the extent that about 20 yrs ago the put Satellite radios in a couple of the mountain cars for use as a trial.
Digital encryptian will never work if LA-RICS is filling in coverage with a tower at your local fire station.or courthouse.
How will that perform up at East Fork or Francisquito Cyn where the mobile radio is lucky to get through.in many places.
If the mountains start to burn fire will have VHF, but what will LASD have when its crunch time other than a lot of dropped transmissions.
I wonder how the sheriffs communicate daily? Normally they can only talk to the dispatcher, the neighboring deputies will hear the beep tone. Let's say if they both stepped out of the vehicle and they need to have radio contact with each other, they switch to TAC channel but wouldn't that mean they both leave the dispatch channel altogether?
LASD does not use any tones/p.l. Never have...not sure why. Great step forward with no busy busy tones.
As for forest coverage they are playing with usfs and installing numerous sites in the mountains to provide coverage that both sheriff, fire and usfs can use. Fyi
Sent from my SM-G955U using Tapatalk
The drop of the busy tone is more because of an outside sheriff than LA-RICS. A specific requirement for that system was that it be able to host the busy tone.
I don't understand your comment...can you please give us a little more info.? Thank you
