last questions for 396T setup
jcanupp
Atlanta GA
Ok..firmware 3.0.2 has zero reception...so I installed 3.0.1. Only a slight improvement. Two questions may help...
1. On P-25 systems, where no rebanding has occurred, do I need to do anything with the band plan for each system?
2. If I reset the radio, using the reset function in the manual, does it just dump your programming, or will it revert to the original firmware too?
Thank you in advance!
hiegtx
Dallas, TX
1. On a "true P25 system", where the system type says something along the lines of "Project 25...", there's no band plan that needs to be entered, with the exception of a very few govt/military systems. I believe, from your past posts, you're talking about this system, right? If that's correct, you would not need a band plan, even when/if the system is rebanded. It is a Project 25 system.
2. The oft mentioned "three finger salute" (holding down the 2, 9, & Hold keys, while powering up the scanner to reset it) will clear the memory, & set search & other settings back to default, but it cannot default the firmware back to a previous version.
Don't know if you've tried this. One thing that came up a few times on some of the firmware upgrades in the past, was that something in the process made a working system no longer work correctly. In those cases, apparently, it somehow corrupted the system info during the process. Have you tried reloading your systems after doing the firmware install? May not make a difference, but would only take a few minutes to try.
At the time the version 3.xx series firmware was released, there was only one actual P25 system in this area (there were a couple of mixed mode systems, not Project 25). There are several now, and more coming. However, I had no trouble with my 396T, hearing the system, after upgrade. So, I'm at a bit of a loss trying to figure out why your's is not working.
jcanupp
Atlanta GA
Yea...that makes 2 of us. I tried to re-install older firmware, like I did before..but it won't now. I've tried to reload the programming, like you suggested..nada. Can't say my next radio will be a Uniden.
hiegtx
Dallas, TX
Well, sorry you're having trouble with your 396T. Not sure what is going on with your radio, but it's not endemic to all samples of the scanner. Mine has not missed a beat. I got it shortly after the model came out in 2005.
ffemt601
MS
Did you follow the upgrade path for your 396t? In your other posts you also referred to it as a 396xt so I am not sure which one you have.
