Latest Astro Spectra ?????
jjflashcode
rescue161 said:
The latest CPS is up to R05.00.02.
If the Latest CPS being R05.00.02 was used to program a Astro Spectra, Can A DOS RSS be used to program or Access the radio or are you compelled to use the same or newer CPS?
Josh said:
Yes, unless the radio you have was last programmed with a CPS version newer than R01.00.00
-Josh
Actually, with the ASTRO Spectra, CPS R02.05.00 matches RSS R09.05.00. Any CPS version higher than that, and you're screwed.
For the XTS3000/Digital Saber, CPS R02.00.00 and RSS R09.05.00 are compatible.
grem467
Houston, TX
Furthermore if you are talking about the Astro Spectra PLUS, you need ASTRO25 mobile, current version is 8.00.00
