BCD436HP/BCD536HP: Latest Firmware update slot mixup
papa_p
Anyone else getting broadcast on slot one coming threw on slot two when programmed DMR One Frequency?
Just after the firmware update I am getting the occasional broadcast that should be on slot one coming out on slot two.
racingfan360
Is the transmission you're listening to simplex DMR, the uplink of a repeater system, or the downlink/base transmission?
Ubbe
Stockholm, Sweden
It's always been like that and is the same with the whistlers. It used to hold on until the user stopped talking but now it's much improved and notice quickly that something isn't right so you only get a second or two until it corrects itself. Is this what you notice or is the slot mixup carrying on for a longer time?
/Ubbe
papa_p
/Ubbe
All transmission used to come out on slot one but now sometimes the transmissions come out on slot 2. If I avoid slot 2 I will miss the odd transmission. Down the road I want to keep the conversations on each slot separate and be able to hold on one slot without missing part of the conversation.
jonwienke
More Info Coming Soon!
VA
Have you considered the possibility that talkgroups may not be locked to a particular slot? Don't filter by slot, filter by talkgroup ID.
papa_p
They use the same talk group ID on both slots but keep their conversations separate on each slot.
papa_p
This is a fire department. They use the same talk group ID system wide. They use slot 1 for satiation 1 and slot 2 for station 2. I want the scanner to display the correct station transmitting.
jonwienke
VA
That is a really stupid way to configure the system. Unlike the slot data itself, the DMR slot ID broadcast between slots has no error correction, so trying to filter traffic by slot ID is always going to be problematic. The correct way to configure a system is to segregate traffic by talkgroup ID rather than slot ID, or there will always be errors of the type you are describing. Unfortunately, there is not much you can do about other people's incompetence.
papa_p
Good to know it’s not the scanner. Thanks
