jfab
After much blood sweat and tears, I got the 2.00.07 update on my 396t and I was just wondering what others are discovering with this update as it relates to Colorado? Thanks!
Not that bad? You're kidding right???:wink: lol...thanks again for the help!:lol:Ryanco said:Big improvement when listening to the DTRS!
I'm with you. I'm not noticing anything...mpg0515 said:What are the improvements that you are all seeing? I haven't noticed any.... CSP is yet again loud as hell! I had great results with 1.11.03 and setting the RES TIME -7 and the REF GAIN +3. I wanted to go back to that version but can't find the old BC VUP firmware updater that will allow me to do that. I noticed this difference almost right away. I also noticed a lot more broken packets on distant sites.
Not noticing anything there either....scanlist said:If you guys have not been lurking in the Uniden forum you may want to take a look at this thread http://www.radioreference.com/forums/showthread.php?t=103667
Seems that some unfortunate issues involving conventional and analog trunking have shown up with this update.
Phil.
Phil.
I am noticing an improvement with DTRS, and nothing else. It's not that anything got worse, it's that it didnt change at all...k0pwo said:I installed the upgrade to my 996t... So far the only improvment I have seen is that it seems to switch between towers a lot more quickly... As for improvment in the digital voice clarity.. I do not see any change at all... In the old version I had gone through manually and changed the setting for the towers that I use the most and had it at what I considered this best sounding.... this upgrade reset those settings and it is now on auto mode...
So I guess I am wondering.. from those of you that said you noticed improvements.. please explain what the improvement is....because I really don't see any...
I hear there is improvment in the edacs... however, I do not have edacs on the 996t as I use it for the dtrs only.. I use the bct15 for edacs stuff....
So tell me what have you seen in the improvement department..
jfab said:I am noticing an improvement with DTRS, and nothing else. It's not that anything got worse, it's that it didnt change at all...
Maybe Uniden is gearing up for an ESK tracking firmware update soon! :lol:
Better signal strength. For example I can monitor a Loveland CC from Broomfield now, and I couldn't before.k0pwo said:So Jfab, as my post asked... what is the improvement that you see in the p25 digital trunking area?
