LAWA Lax Airport PD
scma127
Fontana California
anyone tell me I put the project 25 trunking in my bcd436hp I donoot here nothing at is lax and van nuys air port pd still using the conventional freqs any input would help
LAflyer
Global DB Admin
Moderator
SoCal
Yes they definitely utilize the TRS.
About the old analog frequencies - at LAX 460.525 is the police access channel while 453.375 is still utilized by maintenance. Both 460.100 and 460.55 have been incorporated into the TRS.
For VNY not sure about the old analog frequencies, but I do know the TRS is on the air and used by PD.
scma127
Fontana California
los Angeles World AirPorts
i programmed la city world airports in my scanner and i have yet to hear one transmission on my bcd436hp are they using they freqs and input would help
kearthfan101
They use the p25 trunking system but also still use the conventional frequencies… where are you monitoring from
LAflyer
Global DB Admin
Moderator
SoCal
I hear them everyday. The police and security dispatch being the most active, followed by airfield main.
Keep in mind you need to be somewhere relatively close to either LAX or Van Nuys airport sites to properly receive.
AA6IO
Cerritos, CA (LA County)
LAflyer,
I never hear them in Cerritos. Wonder if I have them programmed wrong, or if Cerritos is just too far from LAX.
Steve AA6IO
AA6IO
Unable to get good decode on the TRS from here in Cerritos. But been running ARC536PRO logging all day on conventional LAWA channels. More than 350 hits for LAX PD 1 on 460.5250, 233 for LAX FMG on 453.3750, and 3 measly hits for VNY 7 PD 1 on 460.4250 (Could actually be LAWA Ont Maint with same PL tone)
Steve AA6IO
