LBI Frequencies
edisonfire
I've got a home in Ortley but I have to admit I've never heard the LBI fire/ems frequencies in use. I'm a fairly straight shot over water to LBI. Are these departments using Ocean TKD system? Can someone confirm use of the VHF frequencies? Roughly what times do the nightly tests occur? Is the signal strength strong? They, especially EMS must be very busy summertime weekends.
158.75250
158.83500
158.73000
159.76500
155.16000
155.23500
153.78500
155.35500
155.38500
151.39250
151.10000
453.66250
elias1988
Station 44 Member
Seaside Heights,NJ
They aren’t using the county trunked system but the fire departments do have radios to communicate when needed with other departments on the system,I have a difficult time getting them on my scanners so you probably are too. Everything listed in the DB under Long Beach Island Emergency Services is up to date.
SVFC462
Connecticut
I was down in LBI last summer (end of June) and Ship Bottom had a fire around the Corner from Ron Jon’s. If I remember correctly .. they were dispatched on the county system and then operated on the simplex fire ground
edisonfire
Elias, a few of the frequencies show as Repeater. Shouldn't that make receiving them easier as I'm not trying to pickup lo-power handhelds per se?
elias1988
Station 44 Member
Seaside Heights,NJ
Yes I have them programmed and I get mostly static using an indoor antenna. Too far South for me to receive unless there’s a good band opening.... Beach Haven,High Point and Ship Bottom FDs have new 700 MHz radios so I’d like to see them move to the new system or at least have their VHF channels patched into it.
BJSCHIEF4900
Surf City NJ
158.75250 Island Wide 1 (R) DPL 031
158.83500 Island WIde 2 (R) DPL 243
158.73000 Island Wide 3 (R) DPL 503
159.76500 Island 4 (S) DPL 243
155.16000 Island 5 (S) DPL 243
155.23500 Island 6 (S) DPL 243
151.39250 Island Wide 7 (R) 18001 Slot 1
155.35500 Island Wide 8 (R) ID 12001 Slot 2 CC 12
155.38500 Island Wide 8 (R) ID 14001 Slot 2 CC 14
153.78500 Fire Police (S) DPL 503
155.35500 Squad 12 DMR (R) ID 12001 Slot 1 CC 12
155.38500 Squad 14 DMR (R) ID 14001 Slot 1 CC 14
151.10000 Squad 49 (R) DPL 516
453.66250 Island Wide 2 (R) Crossband (S) 503
All confirmed
edisonfire
Thx BJSChief, for confirming their use. What I'm wondering is the overall signal strength of these channels. Should I hear these in Ortley, especially the repeater frequencies, just above Seaside?
mshumeyk
Upstate New York
I visit relatives on Barnegat Light at the northern end of LBI a few days each summer and have heard activity on the channels, but signal strength on my handheld scanners is quite weak, certainly not up to what one would expect when you are in the jurisdiction of those agencies. I would therefore doubt that you could monitor them from Ortley.
SVFC462
Connecticut
any other frequencies to program to monitor? -- any other stuff .. Military / USCG?? .. ill be down there for 5 days in two weeks
nosoup4u
High Bridge, NJ
I don't have the frequency info handy, but the Warren Grove Bombing range is nearby. You can catch some of the training flights.
K2YYN
NJ Data Base Admin
NE New Jersey (Clifton)
Need CC on this one: 151.39250 Island Wide 7 (R) 18001 Slot 1
Two Island Wide 8's?:
