LCD Monitor Broadcasts Noise To Radio! Why?
ropehead
I don't operate any wireless equipment at my living location. This includes computers, computer equipment, routers, non-computer equipment, etc.
I'm having a problem with one of my LCD monitors.
It works without problems. That was until I picked up some heavy static noises from a hand held radio. I eliminated all sources of generating this type of noise until I came towards an LCD monitor. When the monitor is on and there is content on the screen the radio makes several types of garbage(static) sounds. As I manipulate contents on the screen, maximize and minimize windows, open different applications, the radio responds with scratchy(static) noises to match the activity on the screen. This includes typing and mouse movement.
When I switched the desktop background to a solid black color without wallpaper, the radio noise went down to almost nothing. But when I loaded any program with a white background, the noise from the radio exploded in volume.
When I passed the radio across different computer and non-computer electronic devices other than the LCD monitor, the wired mouse made a high pitched squeal sound within the static. None of the other computing devices such as the tower generated any noise.
I tried CRT monitors and separate computers attached to the CRT monitors but they did not generate any noise in the radio. On the computer connected to the net, I unplugged the cable leading to the router to rule this out but it made no difference, the LCD monitor is at fault.
While monitoring the radio noise, there were several instances where the noise on the channel being monitored stopped, and I switched to another channel and the same noise appeared. Why would the noise from the LCD switch channels during normal use of the LCD? Back and forth throughout the day the noise generated by the LCD would switch from one channel to the next and back to the first channel again.
The noise extends several steps within my living location. I'll test this another day to determine if it extends outside my living location and if so by how many feet.
The computer/monitor are grounded and attached to a surge protector. I'm not sure what I need to do to stop this, or if I should ignore it.
I assumed LCDs would be quieter than CRTs when it came to noise.
Unless I have a radio tuned to a specific channel, the LCD does not generate any noise which I can detect, unless it's above my hearing capacity.
The LCD monitor also functions as speakers, and while the sound cable is connected to the tower, I have disabled the onboard sound in my BIOS. The only other connection is the DVI cable to the tower.
How may I decrease this noise or eliminate it? It seems like the LCD is a mini radio station. When I turn it off the noise in the radio stops, if I blacken the screen the noise lessens. When I switch to a colorful background or load white screened applications like a web browser the noise jumps up loudly. I've tried grabbing and moving a browser window around the screen and the movement matches the noises in the radio.
Would any of this be considered normal?
kb2vxa
Banned
Point Pleasant Beach, N.J.
The key to this is hand held radio. Obviously you're using it in the immediate vicinity of the computer and all computing devices radiate to some extent. Since your problem is the monitor the solution is simple, move the two farther apart or use an outdoor antenna.
RDGDigital
MD - Eastern Shore
You may want to check the cables for your monitor and mouse. Mice, keyboards, computers and monitors can all create radio frequency interference. Usually the cables for these devices will have ferrite beads (those little bumps on the ends of the cable) to help filter out some of this interference. However, some cables are better than others at filtering this interference. In the past (when I use to work on computers) I've seen cables without any ferrite beads, some with the beads at only one end and others with beads on both ends.
However, even with good cables the devices themselves can generate interference. So the best solution is probably what kb2vxa said above and try to separate the radio from the devices that are producing the interference.
In my case I have two scanners that sit right next to my monitor and I hear no interference at all. However I do have a third scanner (my thirty year old workhorse that I can't bear to part with) that sits about a foot away from my laptop. While this scanner itself doesn't produce any interference, the power supply for it does create some interference. But it's only a problem when i plug or unplug it from the outlet, then it immediately goes away. I can live with that, I just chalk it up to a very old power supply with no interference protection.
lgentle
Lutherville, Maryland
You can also try changing the refresh rate of the monitor and see if that helps.
If your on Windows 7: Right-click on the desktop and select Screen resolution, then click Advanced settings and select the Monitor tab. Just for troubleshooting, uncheck the box that says to Hide modes....... and see if any other refresh rates appear after clicking Apply.
kb2vxa
Banned
"You can also try changing the refresh rate of the monitor and see if that helps."
Those monitors prefer the native resolution and refresh rate, changing them may seriously degrade performance.
k3cfc
Beavertown Pa.
The first thing i would check is the switching power supply for BAD SOLDER JOINTS.
K3CFC
CapStar362
Oakwood GA, USA!
even so, most LCD's you cannot change the refresh unless you force it with the Graphics Control Panel.....after that, most LCD Panels will throw a "Out Of Range" screen or just go black from incompatible refresh frequency. ive seen maybe a few LCD/LED panels that can do 59 and 60 Hz, but 95% of LCD Panels are locked to 60Hz and cannot be changed without errors or forcing it.
K3CFC
next thing i would check is the LCD Back Light CCFL Inverter Board or the CCFL Lamps themselves. thats about the only things, other than the AC Brick (if it has one, as some models of LCD Monitors use straight AC to a PSU Board and not a AC/DC Brick) that uses enough amperage and voltage to generate that kind of EMI
ropehead
@kb2vxa:
"The key to this is hand held radio. Obviously you're using it in the immediate vicinity of the computer and all computing devices radiate to some extent. Since your problem is the monitor the solution is simple, move the two farther apart or use an outdoor antenna."
The noise coming from the LCD monitor is appearing on FRS channels:
- https://en.wikipedia.org/wiki/Family_Radio_Service
It continues for several minutes before it jumps to another channel then after a few minutes jumps back to the original channel. One of my concerns is the ability for others to pluck this noise from the air (Van Eck/TEMPEST) and monitor my activity, or possibly use an attack against the computer somehow. A recent UN report mentioned a high tech method(s):
* U.N. report reveals secret law enforcement techniques
"Point 201: Mentions a new covert communications technique using software defined high frequency radio receivers routed through the computer creating no logs, using no central server and extremely difficult for law enforcement to intercept."
- http://www.unodc.org/documents/frontpage/Use_of_Internet_for_Terrorist_Purposes.pdf
- http://www.hacker10.com/other-computing/u-n-report-reveals-secret-law-enforcement-techniques/
In addition, I don't want my LCD monitor constantly sending monitor and/or system activity to a FRS channel(s) for others to hear. I choose wired over wireless for a reason, and there shouldn't be any noise coming from my LCD monitor and appearing over FRS, unless there is a bug or problem with the monitor. All of my
CRT systems are silent on FRS. Thank you for the help.
@RDGDigital:
Thank you.
@k3cfc:
"The first thing i would check is the switching power supply for BAD SOLDER JOINTS."
Thanks. When I position the radio near different components, the power supply doesn't emit any noise on FRS, but it could be a problem, I don't know, I'll move to that once I resolve the LCD monitor problem, unless the PSU is the problem and not the monitor.
@CapStar362:
"next thing i would check is the LCD Back Light CCFL Inverter Board or the CCFL Lamps themselves. thats about the only things, other than the AC Brick (if it has one, as some models of LCD Monitors use straight AC to a PSU Board and not a AC/DC Brick) that uses enough amperage and voltage to generate that kind of EMI"
I may take apart the LCD monitor, I'm looking for a good list of what I'll find if I do.
I peered inside the vents on the top/back left hand side with a strong flashlight and came across a strange piece of silver tape inside, here's how I describe it:
OO#############__
OO = a small thin black material coming out from underneath the silver piece of tape
## = the strip of silver tape
__ = the bottom right hand portion of the silver tape is raised enough to allow a pinky finger entry
The silver tape/material/opening under tape is on the top left corner inside the monitor. The rest of the length and area inside that I can see contain no tape or black material. I've seen photos of planted bugs in people's living spaces and most if not all of the invasive ones are wrapped/covered in silver foil. I've found no other reason for that strip and material to be there, but what do I know.
note - : I asked elsewhere about this problem and here were the responses. Please feel free to comment on the following:
This certainly isn't unheard of, it's because some part of the monitor is unshielded. The more fix-it stuff is at the top of the following, with the technical backdrop that just might be good to know is at the bottom.
Unfortunately, the issue is most likely the panel charging the LCs. The only thing you can do is see if the manufacturer will replace it or upgrade you. Complain to the manufacturer, be sure to come up with some important thing it's interfering with(if I recall some medical devices use some sort of radio).
If the issue is actually internal wiring which is highly unlikely as detailed below, and it isn't in warranty, attempt to shield it yourself. To shield it yourself, you'll need thin foil(not kitchen foil) and electrical tape.
So, in any given monitor, there's 3 main parts. Input, logic, and output. Output, as previously mentioned, can't really be shielded. To shield both of the other sections, all you really need to do is manipulate the wiring to reduce the number of holes in the foil wrap needed to put it all back together. Obviously this will take some trial and error, and time.
USEFUL INFO THAT ISN'T REQUIRED:
Shielding wires can best be thought of as a encasing a wire in a Faraday cage, made of foil. If you want to see an example, Apple's iPod charging cords are all shielded, strip the insulation and see for yourself. This shielding acts doubly, keeping EM noise from messing with the signal, and keeps the signal's own noise from leaving.
WHY IT IS THE CHARGING PANEL AND NOT WIRING:
Because of the specific details you provided( bravo to you, the amount of data provided helped ), I can conclude that the charging panel(the array of electrodes responsible for producing the image) is putting out the interference. Three of your observations prove this.
First, you state the noise ceases completely when the monitor is turned off, which is consistent with it being EM noise.
Second, the noise's perceived pitch changes when the display is manipulated, which is to be expected, as the electrode charges would change as the display changes.
Third, a black screen is "quieter" than a white screen. Black is the lowest charge state, with the only power in use going to the backlight.
As for your questions:
Noise hopping channels isn't unheard of, though I don't know the science behind it. My best guess is that because the noise isn't an intended result of the electricity, small changes in voltage/amperage result in those hops.
(indirect question-ish) The mouse was likely the only other emitter because it has a fairly high density of wires + it emits light.
You could use kitchen foil, it's just more unwieldy to work with.
Yes, it could be a bug, I was running under the assumption you had no reason to believe you were bugged, and if you did you ran bug sweeps. If you believe you are bugged, you should definitely dismantle things to make sure a bug isn't simply piggybacking on the same power source.
Dimming the screen would reduce noise, but not completely eliminate it.
"Dimming the screen would reduce noise, but not completely eliminate it."
I have modified my browser to function with a black background and my choice of text colors and unchecked the option for all pages to use their own colors, so every page I visit is black with my choice of font/links colors. I'll rescan to determine if this lessens the noise. It's ugly, but tolerable. Coupled with a black theme for the desktop, including the background and system wide applications should also help - including disabling images in the browser.
You mentioned foil. I'm not an electrician, but wouldn't wrapping cords with foil and finishing the job off with a layer of strong black tape possibly conduct electricity? Are you suggesting I cover all wires leading to the computer(s) using this method? Wouldn't they each require special grounding? How many repeating layers of this and/or other material is needed? Have you tried "conductive tubing?"
While I want to shield enough to block noisy RF, I don't want to create a microwave type scenario where RF is contained but it still remains and is possibly amplified so as to add to the degeneration of my health, if that's possible.
1. Ferrite beads
2. Split beads
3. Toroids
CONDUCTIVE TUBING & FERRITE SNAP BEAD
http://www.lessemf.com/wiring.html
https://en.wikipedia.org/wiki/Electromagnetic_interference
https://en.wikipedia.org/wiki/Electromagnetic_radiation_and_health
https://en.wikipedia.org/wiki/Electromagnetic_shielding
https://en.wikipedia.org/wiki/EMF_measurement
I could try some or all of the three options above in addition to your advice? TY
kb2vxa
Banned
You're making a mountain out of a mole hill.
"One of my concerns is the ability for others to pluck this noise from the air (Van Eck/TEMPEST) and monitor my activity, or possibly use an attack against the computer somehow."
You are under the wrong impression that somehow RF hash from the back light can somehow carry data. A liquid crystal display (LCD) does not generate its own light like a CRT or plasma screen and requires a light source to make the display visible. Even those that do cannot transmit computer data being none reaches the monitor.
"In addition, I don't want my LCD monitor constantly sending monitor and/or system activity to a FRS channel(s) for others to hear."
Their FRS radios will only hear what yours does, RF hash, no data whatsoever THAT IS if one is standing outside your house tapping the radio and scratching his head wondering what's the matter with his radio. You and only you know what it is and where it's coming from.
"* U.N. report reveals secret law enforcement techniques"
Thanks for the chuckles, if the report reveals secrets it would not be published but sent by secret courier to the KGB in Moscow.
So... all this and no word on moving the radio farther from the monitor. Why don't you try talking somewhere besides in front of the computer if it bothers you so much?
ropehead
@kb2vxa:
"You're making a mountain out of a mole hill."
I respect your opinion and I don't wish to argue against it, but please look at it from the way I and some others have. I want to eliminate the noise created by the LCD monitor. If this was such a common experience, I would expect at least one of the dozens of other electronic equipment to generate some noise, however faint, on FRS - but they do not.
"You are under the wrong impression that somehow RF hash from the back light can somehow carry data. A liquid crystal display (LCD) does not generate its own light like a CRT or plasma screen and requires a light source to make the display visible. Even those that do cannot transmit computer data being none reaches the monitor."
The LCD is connected to a tower, which other devices connect to. Under testing I've heard the CDROM drive accessing data noises within the FRS channels, along with mouse movements and keyboard activity, along with other noises. When I disable the LCD monitor, all of these disturbances vanish. This means the weakness is in the monitor, and my tower is well shielded or shielded enough so as not to generate any noise in radios I can notice. The reference I made to the strange tape and material within the back side of the LCD monitor at the top could be a sign of some type of antenna or device for amping.
"Their FRS radios will only hear what yours does, RF hash, no data whatsoever THAT IS if one is standing outside your house tapping the radio and scratching his head wondering what's the matter with his radio. You and only you know what it is and where it's coming from."
And what of experienced and curious sysadmins? Rogue crackers? Bored HAMs?
Are there any remote radio injection attacks against systems? This is something I'll research later, as I do believe it was mentioned in at least one whitepaper on side channel attacks.
"Thanks for the chuckles, if the report reveals secrets it would not be published but sent by secret courier to the KGB in Moscow."
I'm not aware of any secrets revealed within the document. But it did raise an interesting point without exposing the method(s) delivered to us from an interesting party. This wasn't just some random article written by some anonymous, disturbed fellow and posted to a pastebin or conspiracy minded blog or forum. And one cannot deny the dozens of TEMPEST attacks available today.
"So... all this and no word on moving the radio farther from the monitor. Why don't you try talking somewhere besides in front of the computer if it bothers you so much?"
Thank you for considering conversation as my reason for posting this, but it is not. I would not choose a noisy channel to talk on. Clear conversation is not the point of this thread. I desire the elimination of this garbage coming from the LCD monitor. I don't care if no one in the world can pick up on it and hear it, I would like to properly resolve it and not ignore it.
One can also dredge up the subject of EMF on health, too, but I have not experienced any disturbance of health from exposure to this noise and most people would argue any possible EMF effects on health to be one of one's over active imagination and not real world application.
A continued discussion was posted elsewhere, this may be useful in the voyage to remove this "noise":
In addition, my CDROM drive light blinks once every second, sometimes with a second or 1/2 second in between, and I found this:
The Risks Digest Volume 19: Issue 60
"I'd worry about a Tempest virus that polled a personal computer's
CD-ROM drive to pulse the motor as a signalling method:
* Modern high-speed CD-ROM drive motors are both acoustically and
electrically noisy, giving you two attack methods for the price of one;
* Laptop computer users without CRTs, and the PC users that can afford
large LCD screens instead of CRTs, often have CD-ROM drives;
* Users are getting quite used to sitting patiently while their
CD-ROM drives grind away for no visibly obvious reason (but
that's quite enough about the widespread installs of software from
Microsoft CD-ROMs that prompted Kuhn's investigation in the first place.)"
"I don't think there should be anymore blinking if you remove the CD/DVD inside."
Does Tails support this at boot?
If not, is there a Linux LiveCD which allows this and does not give you root access at boot?
I've looked at several different distributions which allow you to boot into RAM and remove the CD, but they all give you root and that's a very insecure environment to run the Tor Browser Bundle (TBB) in!
"If it keeps blinking, find out which process uses it."
It doesn't blink on the several distros which boot into RAM, but I don't want to run Tor as root or reconfigure the permissions/PAM/etc. just to use TBB. As above, with Tails and many LiveCDs which don't boot into RAM, 99% of them have this blinking light issue. The actual INSTALLS I've done to HDD experience constant light activity too, even more so, without anything to explain them.
For Linux, I've ran rkhunter, chkrootkit, tiger, and other tools and nothing malicious is found, except for suspect 'strings' within the binaries. Without a deep binary analysis I don't know what else I could do.
For Windows, I use a few programs in the SysInternals Suite and they display strange usage on the system and reference programs which cannot be found with a search on the system, references to impersonation, spoofing, and more. I've ran almost every N.American scanner on the Windows systems, including command line only rootkit detectors and I've seen some strange 'strings' of binaries mentioned, but have no idea on how to clean the system.
I prefer to run LiveCDs because all installations, Windows and Linux, contain unexplainable frenzies of blinking lights, far worse than the blink every second on most LiveCDs. I'm wondering if this is firmware malware on my NIC or the CDROM itself. This has existed for years and never goes away, no matter what system I use, this strange baggage seems to re-infect everything.
"Anyway, you can disable it when you're not using it, if it's bothering you."
"And shield your monitor."
Thanks. I'm investigating and most of the guides require specific addons to the computer's cabling system. Most of the guides appear incomplete, or are in another language other than English.
Any comments on the Tempest/blinking light possibility?
Any comments on why it's spewing out noise to FRS stations and freq hopping?
Any comments on the silver tape and material inside the back of the LCD?
...Disconnection of the LED CDROM and HDD lights could be something I should do to relieve one possible issue.
Some articles with examples:
"If everything is just right, you can pick up signals from some distance. "I was able to eavesdrop certain laptops through three walls," says Kuhn. "At the CEBIT conference, in 2006, I was able to see the Powerpoint presentation from a stand 25 metres away."
uhn also mentioned that one laptop was vulnerable because it had metal hinges that carried the signal of the display cable. I asked if you could alter a device to make it easier to spy on. "There are a lot of innocuous modifications you can make to maximise the chance of getting a good signal," he told me. For example, adding small pieces of wire or cable to a display could make a big difference.
As for defending against this kind of attack, Kuhn says using well-shielded cables, certain combinations of colours and making everything a little fuzzy all work."
- New Scientist Technology Blog: Seeing through walls - New Scientist
TO EASILY VIEW THE PDF files below:
Online viewer for PDF, PostScript and Word:
"This is an online viewer, with which you can view PDF and PostScript files as browsable images and Word documents as web pages. Given a URL on the net or a file on your computer, the viewer will try to retrieve the document, convert it and show it to you. No plugin software is required."
The viewer software is open source, licensed under the GNU Public License.
Electromagnetic eavesdropping risks of flat-panel displays
http://www.cl.cam.ac.uk/~mgk25/pet2004-fpd.pdf
Eavesdropping attacks on computer displays
- http://www.cl.cam.ac.uk/~mgk25/iss2006-tempest.pdf
Compromising emanations: eavesdropping risks of computer displays
- Computer Laboratory – Technical reports: UCAM-CL-TR-577
- http://www.cl.cam.ac.uk/techreports/UCAM-CL-TR-577.pdf
Compromising emanations of LCD TV sets
- http://www.cl.cam.ac.uk/~mgk25/emc2011-tv.pdf
"Q: Can I use filtered fonts also on flat-panel displays
My experience so far has been that with LCDs, the video cable is the most significant source of radiated information leakage. Where an analogue video cable (with 15-pin VGA connector) is used, low-pass filtered fonts have the same benefits as with CRTs. Where a purely digital video cable is used (DVI-D, laptop-internal displays with FPD/LVDS links, etc.) only the last step, namely randomizing the least-significant bits, should be implemented.
Where the video signal is entirely encoded in digital form, the low-pass filtered step will not have the desired effect. In fact, it can actually increase the differences between the signal generated by individual characters, and thereby make automatic radio character recognition more reliable."
- Soft Tempest FAQ
Remotely Eavesdropping on Keyboards (and read the comments!)
"The researchers from the Security and Cryptography Laboratory at Ecole Polytechnique Federale de Lausanne are able to capture keystrokes by monitoring the electromagnetic radiation of PS/2, universal serial bus, or laptop keyboards. They've outline four separate attack methods, some that work at a distance of as much as 65 feet from the target.
In one video demonstration, researchers Martin Vuagnoux and Sylvain Pasini sniff out the the keystrokes typed into a standard keyboard using a large antenna that's about 20 to 30 feet away in an adjacent room."
- https://www.schneier.com/blog/archives/2008/10/remotely_eavesd.html
Video eavesdropping demo at CeBIT 2006
- Light Blue Touchpaper » Blog Archive » Video eavesdropping demo at CeBIT 2006
Optical Emission Security – Frequently Asked Questions
"Q: What about LEDs?
For devices with RS-232 serial ports, it is customary to provide a status indicator LED for some of the signal lines (in particular transmit data and receive data). Often, these LEDs are directly connected to the line via just a resistor. As a result, anyone with a line of sight to the LED, some optics and a simple photosensor can see the data stream. Joe Loughry and David A. Umphress have recently announced a detailed study (submitted to ACM Transactions on Information and System Security) in which they tested 39 communications devices with 164 LED indicators, and on 14 of the tested devices they found serial port data in the LED light. Based on their findings, it seems reasonable to conclude that LEDs for RS-232 ports are most likely carrying the data signal today, whereas LEDs on high-speed data links (LANs, harddisk) do not. Even these LEDs are still available as a covert channel for malicious software that actively tries to transmit data optically.
I expect that this paper will cause a number of modem manufacturers to add a little pulse stretcher (monostable multivibrator) to the LEDs in the next chip set revision, and that at some facilities with particular security concerns, the relevant LEDs will be removed or covered with black tape.
The data traffic on LEDs is not a periodic signal, and therefore, unlike with video signals, periodic averaging cannot be used to improve the signal-to-noise ratio. The shot-noise limit estimation technique that I used to estimate the CRT eavesdropping risk can even more easily (because no deconvolution is needed) also be applied to serial port indicators and allows us to estimate a lower bound for the bit-error rate at a given distance. I have performed a few example calculations and concluded that with a direct line of sight, and a 100 kbit/s signal (typical for an external telephone modem), at 500 m distance it should be no problem to acquire a reliable signal (one wrong bit every 10 megabit), whereas for indirect reflection from the wall of a dark room, a somewhat more noisy signal (at least one wrong bit per 10 kilobit) can be expected to be receivable in a few tens of meters distance.
- Optical Emission Security FAQ
Ancient Story on Slashdot: Coming to a Desktop near you: Tempest Capabilities
"New Scientist has an interesting article about a new toy we will all want. It's a card that plugs in one of your PCI slots and allows you to scan the EMF spectrum and read your neighbours terminal. In about 5 years you might be able to get one for just under £1000. (Modern Tempest Hardware costs about £30000) "
Coming to a Desktop near you: Tempest Capabilities - Slashdot
"Any unshielded electrical device with a variable current (including LCDs) will give out EMF radiation. It's the nature of the beast.
For that matter, light is EMF radiation, so unless you have your LCD in a coal-mine, it's reflecting EMF all the time it's switched on.
Then, there's the fact that screen monitoring isn't the only monitoring you can do. I used to use a radio, tuned into the bus for the PET, as a sound card. Worked surprisingly well, for all that very clunky metal shielding. What's to stop a much higher-quality receiver from seeing the data, in an unshielded box, being sent TO the LCD, or to any other device on the machine?
It's a mistake to assume that Tempest technology is single-function and that that single-function only works in a single situation."
- Coming to a Desktop near you: Tempest Capabilities - Slashdot
800Mbps Wireless Network Made With LED Light Bulbs
- 800Mbps Wireless Network Made With LED Light Bulbs - Slashdot
There are a lot of other files, many in PPT format, which can be found easily on this subject of LCD monitor (and other computing devices) TEMPEST sniffing.
kb2vxa
Banned
Sorry if I don't have time to read your book and everything I say about the monitor being a security issue falls on deaf ears and I'll keep the tin foil hat comment to myself. I'll say but one thing on it in conclusion, NORMAL security concerns center on internet access it being the ONLY link to the outside world.
That having been said I refer you to the other posts regarding the back lighting power supply generating and radiating RFI which was the issue to begin with.
evfd1625
Indiana
Wirelessly posted (Opera/9.80 (Android 4.0.4; Linux; Opera Mobi/ADR-1212030829) Presto/2.11.355 Version/12.10)
Unless all monitors are bugged from the factory, or someone has come into your residence to bug it, buying a monitor that has been bugged and is waiting for you with the chance you might get it is like buying a package of socks from Walmart with a GPS tracking device. Consumer electronics radiate all over the place. Cheap materials that only have to not cause harmful interference.
lgentle
Dude, you have a defective monitor. Simple as that.
Agreed. Newegg is your friend.
We don't know the make and model of the monitor. Whether the monitor is plugged into a surge surpressor or a UPS or directly into a wall outlet.
ropehead
Thanks for all of the great posts! I haven't the time at the moment to address them all. For now I'll leave a quote from a response elsewhere:
@OP:
"I'd worry about a Tempest virus that polled a personal computer' personal computer' CD-ROM drive"
Yes and the hard drive and in some PC's the cooling fans as well are under CPU control.
You can also do it with PC's where the CPU does not control the fan, but the hardware has a simple thermal sensor to control it's speed. You do this by simply having a process that uses power expensive instructions in tight loops, thus raising the CPU temprature (it's one of the side channels I was considering a long time ago when thinking about how the temp inside the case changed various things including the CPU clock XTAL frequency).
The change in sound side channel is one of the first identified problems with Quantum Key Distribution. Basicaly the bod who came up with the idea whilst first testing the idea could tell the state of "Alice's polarizer" simply by the amount of noise it made...
The CD-ROM motor idea I'd heard befor but could not remember where till I followed your link.
Dr Lloyd Wood has worked with the UK's Surrey Uni, the European Space Agency and Americas NASA and one or two other places as part of his work for Surrey Satellite Technology Ltd. He has been involved with CLEO (Cisco router in Low Earth Orbit) and other work on what's being called "The Space Internet".
Of interest is his work on Delay and Disruption Tolerant Networks (DTN). It's not been said "publicaly" as far as I'm aware but the work has aspects that are important to anonymity networks such as TOR.
You can read more on Dr Wood's DTN work etc at,
Lloyd Wood - Delay-Tolerant Networking work
The UK occupies an odd position in the "Space Race" it is the only nation who having put a satellite into space then stopped further space rocket development (the Black Knight launch platform was considerably safer and more economic than the then US and CCCP systems). The UK has however continued in the Space Game and is perhaps the leading designers of payloads for scientific and industrial satellites (it probably is on military sats as well but nobody who knows for sure is telling ;-)
Clive Robinson
Schneier on Security: Information-Age Law Enforcement Techniques
kb2vxa
Banned
Why try to reason with a stone? It's all been said to no avail so it's time to pack your tent and move on. Byeeeee......
jhooten
Paige, Republic of Texas
Have you noticed any nondescript white vans or black helicopters in your neighborhood?
What do you do or have you done to make "them" take such an interest in you that "they" have to bug you?
You need a bigger tinfoil hat, perhaps a full body suit.
Look in the dictionary under paranoid to see if your picture is there.
The Monitor has a problem take it back.
BTW, ditch the FRS radios. The Men In Black monitor them and send subliminal messages out over them.
wmetech1
Bedford, NY, USA
:lol: :lol:
BOTTOM LINE: No matter WHAT you do, all devices that use electricity will emit some sort of interference in the air and there's nothing you can do about it without unplugging/turning it off.
You CAN buy the ferrite cable cores that RDGDigital mentioned (see below), but I honestly don't think that will make a very significant difference. Your best bet, as others said, is move your radio equipment further away.
