I am running LCN finder on an SDS100 and would like to see the LCNs it found before all have been identified. How can I see the LCNs/frequencies? The manual doesn't address how to do that.
When you exit the LCN Finder, you should see a prompt to save what was found. Once you save & exit, then you can 'read' the scanner into Sentinel (or other software), then review the system to see what LCNs were found.
Or, after exiting (and saving), you can go through the "Manage Favorites Lists process & select "Edit" for each site frequency. That will show you the frequency entered. If you then hit Enter, you'll see the LCN found (if any). LCNs not found will still show a
0 (zero) in the LCN field.
Remember that if you save to Sentinel, then later want to re-run the LCN Finder to look for more, the scanner will reset
all LCNs to zero, not just the ones not found yet.
