Lcra p25
KTR722
LCRA 113-13 - BASTROP
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 200
System Name : Lower Colorado River Authority (LCRA) P25
WACN : 92571
Tower Number (Decimal): 113-13
Tower Number (Hex) : T710D
Tower Description : Bastrop
Control Capabilities : Data,Voice,Registration
Flavor : Phase 1
Call Sign(s) :
Timestamp : Sat Oct 17 12:32:13 2020
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,769.00625,0.01250,30.00000,"Confirmed",0.01250,1
01,851.00000,0.01250,-45.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0037","c",769.46875,"00-0037",799.46875,0,0
"00-0097","v",770.21875,"00-0097",0.00000,0,1
"00-0157","av",770.96875,"00-0157",800.96875,0,2
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
10101,"T6501",200,"00-0035",769.44375,"Austin"
10202,"T6602",200,"00-0324",773.05625,"Creedmoor"
10505,"T6905",200,"00-0016",769.20625,"Flatonia"
10606,"T6A06",200,"00-0135",770.69375,"Gonzales"
10707,"T6B07",200,"00-0424",774.30625,"Kingsbury"
11111,"T6F0B",200,"00-0036",769.45625,"La Grange"
11616,"T7410",200,"00-0343",773.29375,"Rutersville"
11717,"T7511",200,"00-0015",769.19375,"Giddings"
KTR722
LCRA 127-27 - DRIPPING SPRINGS
FileVersion:8
-TowerInfo
System ID : 200
WACN : 92571
Tower Number (Decimal): 127-27
Tower Number (Hex) : T7F1B
Tower Description : Dripping Springs
Flavor : Phase 1
Call Sign(s) :
Timestamp : Sat Oct 17 15:04:10 2020
-Tables
-Frequencies
"00-0015","vd",769.19375,"00-0015",799.19375,0,4968
"00-0052","cavd",769.65625,"00-0052",799.65625,0,15
"00-0075","cvd",769.94375,"00-0075",799.94375,0,5005
"00-0112","avd",770.40625,"00-0112",800.40625,0,5051
"00-0135","avd",770.69375,"00-0135",800.69375,0,5083
-Neighbors
10404,"T6804",200,"00-0426",774.33125,"San Marcos"
11414,"T720E",200,"00-0344",773.30625,"Johnson City"
11515,"T730F",200,"00-0327",773.09375,"Spicewood"
12121,"T7915",200,"00-0077",769.96875,"Luckenbach"
12626,"T7E1A",200,"00-0097",770.21875,"Wimberley"
jbsarandolphmonitor
Air band monitoring JBSA-Randolph
Schertz, TX
site 132-32 switched site numbers to 131-31. I have been told that site 131-31 is located in Cibolo. The seguin site is not on the air yet.
Don
KTR722
If you map out what I got this morning, this is what it looks like. I apparently did not go far enough south to see anything that 131-31 said it was connected to on the most recent post up above (those links are in Yellow) but I did connect with 102-02 Creedmoor and 104-04 San Marcos and neither site was reporting either 31 or 32 as a neighbor. 131-32 (links in white) was reporting 102-02 Creedmoor as a neighbor previously.
jbsarandolphmonitor
Schertz, TX
Here is the tower information for the Cibolo site
FileVersion:8
-TowerInfo
System ID : 200
System Name :
WACN : 92571
Tower Number (Decimal): 131-31
Tower Number (Hex) : T831F
Tower Description :
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sat Oct 17 15:20:26 2020
-Tables
08,769.00625,0.01250,30.00000,"Confirmed",0.01250,2
09,851.00000,0.01250,-45.00000,"Confirmed",0.01250,2
-Frequencies
"00-0052","avd",769.65625,"00-0052",799.65625,0,6
"00-0112","avd",770.40625,"00-0112",800.40625,0,8
"00-0342","c",773.28125,"00-0342",803.28125,0,0
"00-0365","avd",773.56875,"00-0365",0.00000,1,6
"00-0402","avd",774.03125,"00-0402",804.03125,0,8
"00-0425","avd",774.31875,"00-0425",804.31875,0,9
"00-0462","avd",774.78125,"00-0462",804.78125,1,6
"08-0104","v",769.65625/0,"08-0104",799.65625/0,0,1
"08-0224","v",770.40625/0,"08-0224",800.40625/0,0,2
"08-0730","v",773.56875/0,"08-0730",803.56875/0,0,2
"08-0804","v",774.03125/0,"08-0804",804.03125/0,1,1
"08-0924","v",774.78125/0,"08-0924",804.78125/0,1,2
-Neighbors
10303,"T6703",200,"00-0053",769.66875,""
10707,"T6B07",200,"00-0424",774.30625,""
11919,"T7713",200,"01-0223",853.78750,""
12323,"T7B17",200,"00-0346",773.33125,""
Don
KTR722
Don
Don, are you able to pull anything from Live Oak, New Braunfels, Kingsbury, Smithson Valley or any other neighbors from where you are at and post so we can compare?
jbsarandolphmonitor
Schertz, TX
Here is the tower info for the Live Oak site.
FileVersion:8
-TowerInfo
System ID : 200
System Name :
WACN : 92571
Tower Number (Decimal): 119-19
Tower Number (Hex) : T7713
Tower Description :
Control Capabilities : Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sat Oct 17 15:54:25 2020
-Tables
-Frequencies
"01-0026","av",851.32500,"01-0026",806.32500,0,1
"01-0066","av",851.82500,"01-0066",806.82500,0,1
"01-0127","av",852.58750,"01-0127",807.58750,0,1
"01-0151","av",852.88750,"01-0151",807.88750,0,1
"01-0169","av",853.11250,"01-0169",808.11250,0,1
"01-0187","av",853.33750,"01-0187",808.33750,1,1
"01-0205","av",853.56250,"01-0205",808.56250,1,1
"01-0214","av",853.67500,"01-0214",808.67500,1,2
"01-0223","c",853.78750,"01-0223",808.78750,0,0
"01-0233","av",853.91250,"01-0233",808.91250,1,2
-Neighbors
12020,"T7814",200,"00-0034",769.43125,""
12222,"T7A16",200,"00-0116",770.45625,""
13131,"T831F",200,"00-0342",773.28125,""
Don
KTR722
Thanks Don, here is the updated map with Cibolo (31) and Live Oak (19) overlayed. The Cibolo site location on the map is approximated. If anyone posts any more site info i will update and re-post for the group.
jbsarandolphmonitor
Schertz, TX
Here is the tower info for the Smithson Valley site.
FileVersion:8
-TowerInfo
System ID : 200
System Name :
WACN : 92571
Tower Number (Decimal): 123-23
Tower Number (Hex) : T7B17
Tower Description :
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sat Oct 17 16:13:06 2020
-Tables
-Frequencies
"00-0323","v",773.04375,"00-0323",0.00000,0,0
"00-0346","c",773.33125,"00-0346",803.33125,0,0
"00-0383","v",773.79375,"00-0383",803.79375,0,1
"00-0406","av",774.08125,"00-0406",804.08125,0,1
"00-0443","av",774.54375,"00-0443",804.54375,0,0
"08-0646","v",773.04375/0,"08-0646",0.00000/0,0,0
"08-0766","v",773.79375/0,"08-0766",0.00000/0,0,0
"08-0812","v",774.08125/0,"08-0812",0.00000/0,0,0
"08-0886","v",774.54375/0,"08-0886",0.00000/0,0,0
-Neighbors
10404,"T6804",200,"00-0426",774.33125,""
11414,"T720E",200,"00-0344",773.30625,""
12121,"T7915",200,"00-0077",769.96875,""
12626,"T7E1A",200,"00-0097",770.21875,""
Don
KTR722
Updated with Smithson Valley. Don's decodes are darker blue; last known Site 32 (presumed Seguin?) decode is in white.
KF5YBV
Lohn, Texas
To add to the LCRA System, Brown County Commissioners approved a contract to move all public safety communications to LCRA. Possible project completion in March or April.
2101
New Berlin
howdy all, lcra transition is moving along. cibolo site is up and running while the seguin and hickory forest site are still not quite operational but due to be by end of October early November. currently, VFD's in the county are not yet using the system however will be once hickory forest site is operational. patches will be in place to the current n and s digital repeaters and analog repeaters for fire. also look for patches with the New Berlin Common repeaters (renamed to NBVNET 1 etc) and the marion repeater. most if not all vfd comms will be in phase 1 while SO will most likely be phase 2. look for 9 fire ops tg's, a couple ems tg's, common tg for entire fleet and fmo tgs in addition to SO and Seguin already identified.
Sanscanman
N5WRF
Acworth, GA
Kingsbury Site Audit
System ID : 200
WACN : 92571
Tower Number (Decimal): 107-7
Tower Number (Hex) : T6B07
Tower Description : Kingsbury
Flavor : Phase 2
Call Sign(s) :
Timestamp : Thu Oct 22 22:46:34 2020
-Tables
-Frequencies
"00-0117","av",770.46875,"00-0117",800.46875,0,10
"00-0154","avd",770.93125,"00-0154",800.93125,0,7
"00-0327","a",773.09375,"00-0327",803.09375,0,0
"00-0364","av",773.55625,"00-0364",803.55625,0,12
"00-0387","avd",773.84375,"00-0387",803.84375,0,10
"00-0424","c",774.30625,"00-0424",804.30625,0,0
"00-0447","avd",774.59375,"00-0447",804.59375,1,8
"08-0234","v",770.46875/0,"08-0234",800.46875/0,0,2
"08-0308","v",770.93125/0,"08-0308",800.93125/0,0,2
"08-0774","v",773.84375/0,"08-0774",803.84375/0,0,1
"08-0894","v",774.59375/0,"08-0894",804.59375/0,0,2
-Neighbors
10303,"T6703",200,"00-0053",769.66875,"New Braunfels"
10404,"T6804",200,"00-0366",773.58125,"San Marcos"
11313,"T710D",200,"00-0037",769.46875,"Bastrop"
11919,"T7713",200,"01-0026",851.32500,"Live Oak"
13131,"T831F",200,"00-0342",773.28125,"Cibolo"
KG1ADP
Moto
Texas
Cibolo I using 773.21825 as a CC right now.. the DB has 769.65625 as the only only valid cc for the site
The harris system uses any of the frequencies as control channels they change constantly....
Sanscanman
N5WRF
Acworth, GA
Saw TG 8040 key up several times this morning.. no audio was present just a low barely audible buzz/hum coming across. wondering if this is linked to a VHF repeater for possibly Green Valley Water(158.2650) which Marion and New Berlin VFD's use as a tac channel. The TG was active between 5:30 ish to about 7 am, I also wondering if it could be New Berlins Common 2(154.4900) and it was rebroadcasting skip, they used to have an issue with a repeater on the same freq and PL that would create havoc for them overnight.
Sanscanman
N5WRF
Acworth, GA
Gonzales site audit:
FileVersion:8
-TowerInfo
System ID : 200
WACN : 92571
Tower Number (Decimal): 106-6
Tower Number (Hex) : T6A06
Tower Description : Gonzales
Flavor : Phase 2
Call Sign(s) :
Timestamp : Mon Oct 26 20:19:30 2020
-Tables
-Frequencies
"00-0015","av",769.19375,"00-0015",799.19375,0,2
"00-0075","v",769.94375,"00-0075",799.94375,0,2
"00-0135","c",770.69375,"00-0135",800.69375,1,0
-Neighbors
