If the bat board site won't let you make a new ID due to your email address, that may be an
indication that you use to be on the group before and violated their rules. You got yourself
bared from the site.
On the subject of version 6, it is not a software thing, but the version of the firmware on
the MLM board that holds the internal RAM memory software in the radio. The way you
upgrade to a higher version is to physically replace the plug in MLM board. Then you
might even have to obtain a codeplug of a radio that had zone in it. I have done this
to a couple of radios that I currently use.
Word of experience, is to put down on paper each zone and the channels you want in
the zones before you even start trying to change the modes or channels in the radio.
You can loose your place real fast when reprogramming the Spectra. It is not very
user friendly in helping you keep track where you are while programming it.
You can also set up the scan in the radio at the same time you playing with the mode
input. Again, make sure you put it all down on paper prior to working on programming
the radio. The radio will let you have a different scan list for each channel in the radio.
I set mine up with the priority channel as the selected channel and went from there.
the other channels you want to scan would almost fall into place once you get the
hang of what your doing.
Jim
Hmm.. If its been fixed before i have no idea. When i got it came with the fail.
ANd i cant get onto batlabs.. My user name no longer works.. and it wont let me make a new account due to my email address. Yahoo and hotmail dont work
