ebook2cw
ebook2cw - convert ebooks to morse mp3s
Using this program, you can take an ebook from
Main Page - Gutenberg
and turn into an mp3 file in cw. Its wise to clean the file up a bit by taking the beginning license
and ending license material out, and also to get rid of quite a bit of punctuation. It works great.
Also I figured out a way to get this program to create vocab mp3 files in much much less time
than it would take to do individually.
Just take the attached text file and put in the proper info into ebook2cw and you will get almost 1000
of the most commonly used words in the english language in cw at whatever speed you want.
Instead of author put 1000 words, Instead of title put 500 hz 40 wpm.
Just be sure to create separate directories for the different groups. Its a lot of files.
I created the text file on emacs after having trouble getting a spreadsheet to properly format it.
Since ebook2cw is set up to do books I had to make some compromises.
The program is set up to create a new file at the beginning of every chapter in a book. To do that
you have to tell the program what word to look for in the file. Usually its CHAPTER, so to make vocab
lists I had to find the shortest separator word I could find and the program seemed to be fine with
the letter 'e' , so that is what I went with. There are 2 e's at the beginning of the line because I guess the program is expecting a number or something after the chapter separator.
Then the word will be repeated three times. I tried to add spaces in between the words and mostly succeeded but to do anything above 40 wpm I would like much more space in between the words so I will have to do another file for those speeds. (not that I am actually able to do those speeds yet).
At the end of each file is the Break <bt> symbol - . . . - .
ebook2cw takes every new paragraph and translates that into the <bt> symbol so there is no need to
do that manually. And somehow with emacs I created the paragraph separator by using rectangle editing.
Give it a shot. The only drawback is that the title of each file is a number rather than the 'word' that is in cw, but who cares. It would take forever to create a 1000 mp3.
Now if I could only get my cheapo mp3 player to see all of the files I have added to it, I would be in business. It only sees about 2000 of the files.
The most difficult by far was the text file. Make changes at your own peril.
e e
the the the
becomes this in cw in an mp3
e e the the the <bt>
Have fun !!!!!!!!!!
