Led Entry Problem;
betta
24309 Linda Ln. Porter, Tx. 77365
What are the steps needed to add the RED COLOR LED that i chose for the frequencies in scan
list 01. I have uhf and vhy frequencies in scan list 01. I assigned RED fot the color of the LED that
i wanted for scanlist 01. I chose the COLOR AND THE LED THAT I WANTED, BUT THE LED NEVER LIT UP.
This is all that i need, just the MANUAL ENTERY STEPS.
THANKS FOR ANY AND ALL REPLIES...............BETTA
guitarbrian30
Bismarck ,ND
check your LED color in the Global menu. Sounds like you have it "BLACK" not RED like you want. You would have set the object being scanned as color red.
push PGM
Push F3 to access GLOBAL menu
use down arrow to head to EXPERT BELOW. You will find LED COLOR #1
Or just change your object LED to whatever LED you have in your globals.
Hope this helps you out.
