Lee County NC Going to VIPER
gspivey
North carolina
Lee County NC Sheriff went live on VIPER today (8-25). In the next month or two you should hear Lee County Fire (including Sanford Fire) and Lee County EMS transition to VIPER. Sanford Police chose to stay on their UHF system.
This should be in the VIPER thread, great info for those following VIPER. Thank you for the update!
richardbritt
State of NC
Northeastern NC
Also please post it as a submission to the database if it's not not accurate as far as the actual talkgroups you hear being used. Thank you very much
It is talkgroup 27009. I’ve submitted to the database.
Many of the Lee Co SO TGs have been in the database since last October...
270096981DLEESOLee County SheriffLaw DispatchLee County2014-10-25
270106982DLEESOADMINLee County Sheriff AdminLaw TalkLee County2014-10-25
270116983DLEESOCIDLee County Sheriff CIDLaw TacLee County2014-10-25
270126984DLEESONARCLee County Sheriff NARCLaw TacLee County2014-10-25
270136985DLEESOOPSLee County Sheriff OPSLaw TacLee County2014-10-25
270146986DLEETACLee County TACMulti-TacLee County2014-10-25
270156987DLEETAC2Lee County TAC 2Multi-TacLee County2014-10-25
270166988DLEETAC3Lee County TAC 3Multi-TacLee County2014-10-25
270176989DLEETAC4Lee County TAC 4Multi-TacLee County2014-10-25
27018698aDLEETAC5Lee County TAC 5Multi-TacLee County2014-10-25
27019698bDLEETAC6Lee County TAC 6Multi-TacLee County2014-10-25
27020698cDLEETAC7Lee County TAC 7Multi-TacLee County2014-10-25
27021698dDLEETAC8Lee County TAC 8Multi-TacLee County2014-10-25
yardbird
Concord, NC
I am probably ruffle some feathers if I do I am sorry.
Looks like Lee/Sanford learned a lesson from trying to operate their own system.
Both Brunswick and Columbus Counties finally ditched their systems for Viper.
I give it time Henderson and Polk Counties will be ditching their NXDN system for Viper.
These counties are finally waking up and realizing that Viper is the only way to go for interoperability.
The only cost involved is the radios.
The highway patrol maintains the infrastructure, so why not jump on board.
My congrats to Lee County of the switch to Viper.
GMB2711
Spring Lake, NC
Confirmed 27009 looks like they will use the listed talk groups already in data base unless they add some more
Tg #27009 Sheriff.
richardbritt
State of NC
Northeastern NC
Make sure you submit anything that needs to be changed on the Lee County site to the Lee County specific page. If you submit it to when you are on the Viper page, it won't be seen by a Lee county database administrator and the changes won't be done. I don't have the ability to transfer a VIPER submission to a county level database administrator. Thank you for your support
Chris0516
Pittsboro, North Carolina
I am not in any of those counties, so. Can't ruffle my feathers. Lee is a neighboring county to mine. I activated the NXDN on my 436HP, several years ago. Because of what they were using. I never could hear it. After I received my SDS100, as an early Christmas present, a year after I was given my 436HP. I decided not to activate the NXDN. I was elated, when I found an article last year, that. Said something about a retired Fire Chief doing an analysis of the Lee County system. Saying a move to VIPER would improve response times.
Sanford,NC
The only activity I've heard on their NXDN in the past year is COLTS, simulcast of EMS, and occasional fire tac channel activity
trumpetman
Charlotte, NC
Based on a RRDB submission, all public safety in Lee County should be primary on VIPER as of yesterday, 9-18, with the exception of Sanford PD "still using their UHF channels". Not sure if that means NEXEDGE or conventional analog.
Chris-KH2PM
Northern Harnett Co. NC
Sanford PD is very active still on conventional analog 460.175 MHz.
DavidQ
Sanford, NC
Lee County trunk question:
Which antenna site is Lee County using? Broadway/Tramway I live by Juniper Springs Baptist Church- Buckhorn Rd.
I have programmed the Broadway tower frequencies and FIRE TGID's into my BCD996P2. I have good signal strength and consistently receive Fire Dispatch. I am not hearing the different fire departments on their respective Talk Group when listening. I have tried switching to ID SEARCH when I hear a dispatch to see if I would pick up a different TGID but have had no luck. I do pick up LCSO, EMS and some Harnett County units when in ID SEARCH mode. Any recommendations?
Thanks- David Q.
Chris0516
Thanks- David Q.
I would like to know the answer, too.
