Legal, License Free 902-928 mHz ISM Band Portables
JASII
Memory Capacity
Although this isn't either GMRS/FRS/MURS, this seems to be the most appropriate sub-forum for this thread. I am aware of the Motorola DTR radios and the Tr-Suaare, both of which operate on 902-928 mHz. Anyway, what I am wondering is if it is permissible in ITU Region 2 to get any commercial transceiver, program it for any frequencies betwee 902 and 928 mHz, and operate legally at 1 watt or less? Now I know that there are some limitations on GMRS/FRS/MURS, but could a person at 1 watt use ANY antenna? Also, if there any limitation on what equipment that can be used? I know that FRS is supposed to have a fixed antenna and GMRS is supposed to be licensed. I guess one example that I am wondering about is if you could legally use an amateur radio on that band? What I am considering is using an Alinco DJ-G29T. Can that be used by non-hams legally at 1 watt or less or are there some other restrictions on that band that require a different type of radio? It looks like Motorola has made some 900 mHz gear, so would those be permissible for non-hams at 1 watt or less in the US or anywhere in ITU Region 2, for that matter?
ISM band - Wikipedia, the free encyclopedia
International Telecommunication Union region - Wikipedia, the free encyclopedia
Exploring 900 MHz - 900 MHz Radio Modifications
