Leixen vv-898
muddyboy
Sandwich
i am new to the community and just dabbling in amatuer radio, really just learning programming and listening at the momment but here's my delema.....i bought a Leixen vv-898 transever programmed it with some local freq (using Chirp) and put it in my truck, I should also say that I occasionally use it for work and we have our own freq and repeater before I get yelled at. I am taking a long driving trip and planned on having some FRS freq programmed for emergency situations and so I could communicate with the other driver I am following but when i go to program it tells me "radio refused programing" and I can't find any useful info in the OM or online. any suggestions as to what may be the issue or did this thing just quit on me? thanks for your help
Sconnick
It won't take long for someone to jump in here, so I'll do it nicely, and note that you can't use that radio for FRS.
N4GIX
Hot Springs, AR
While it is correct that you cannot (legally) use the VV-898 for FRS, it is perfectly possible to program those frequencies and listen to them...
Sconnick
That is true. You can program a wide range of frequencies into that thing.
I understood the following quote to indicate that he would be using the frequencies to transmit on:
N4GIX
Hot Springs, AR
I was only addressing the remainder of that sentence "...but when i go to program it tells me "radio refused programing""
