Leixen VV-898
DanDanRadioMan
Haines City
I have a Leixen vv-898. Does anybody no why the radio wont stay on a received channel.I have plenty of signal,(shows on the bar graft)
but when talking the voice stops and starts. sort of like priority on. But when I put it on one channel still get the same thing.
Dan KC1JYS
2IR473
Do those radios have a “Dual Watch” function ? I have one, but it’s packed away and haven’t used it in several years.
If it has dual watch, it would “look back” at the other channel it is monitoring every few seconds, causing a situation such as you describe.
Also, on scan, you can usually set the scan feature to several modes...CO,TO, SE. CO is “carrier“ and it would stop on the channel while there is a carrier present. TO would be a timed pause, and start scanning again after the timer is reached, regardless of the presence of a carrier. You might check that as well.
