lc2413rp
Download Conventional to digital scanner Pro-106 & 197...Lexington FD 158.805 not working on digital, analog 158.805 OK...Giddings FD 154.400 Digital and Analog OK....lc2413rp
Some how we are not communicating.I understand there are no digital conv. freq on the download from Radioreference.com...the Gidding FD at 154.400 is OK...Lexington FD 158.805 is not working...these freq are on the same download from RR.com under Texas..Lee County...Conv..
If you are saying you have an analog scanner that picked up 158.805 during this test but the digital scanner didn't, then you did not program the digital scanner correctly. Certainly a new digital scanner is capable of hearing an analog signal.After I manually installed 158.805 in the digital scanner..I called the dispatcher for a test...Nothing on the digital scanner..the analog scanner worked
The reason 154.400 has a PL is because there is a PL on the channel that has been reported to us. The reason the 158.805 does not have one, is that either they don't use one or it has not been reported to us. The blank seems to indicate that we are unclear if there is supposed to be one or not; a problem you could have solved easily during that test if you had your scanner (the analog one) in a "tone search" mode.OK...Why I keep coming back to the download from RR.com...is the download on Giddings FD 154.400 shows a PL with a freq behind it...On Lexington FD there is no PL or freq....Giddings FD is OK on digital...Lexington FD is not on the digital scanner...lc2413rp....r.paskett@yahoo.com
