Yes - 367 works. The posts above were referring to the expected library 368, which should have appeared on Saturday 21 June.I updated my 800 last night,Was good to go.Full update onto a new install of EZScan.
It took about 45 seconds..
library 367 and location 10..dated last week
Problem found. Recent changes to Minnesota's ARMER system (erasing contents of site names, instead of filling with "EMPTY" as had been done before) caused null pointers in .NET. Unhandled exception being thrown.The update process (DB retrieval from RR) has been failing after about 4.5 hours. I'm investigating it.
Well, since DonS is the guy who runs the database download, I'd say his is the real reason.There was a separate post in another thread about the delay being caused by turning over the database responsibility to Whistler as the reason. Does anyone know the real reason?
Sounds Good, thanks manProblem found. Recent changes to Minnesota's ARMER system (erasing contents of site names, instead of filling with "EMPTY" as had been done before) caused null pointers in .NET. Unhandled exception being thrown.
New library build will start shortly. Will be done late tonight.
