Lightning Arrestor for RG-6?
kc8lzg
Zeeland, Michigan
I decided to feed my scanner with RG-6 Quad Shield but confused about proper lightning arrestor. Does the 75 ohm cable create an issue with 50 ohm rating on the arrestor? Does staying with the "F" connectors create another issue?
kc8lzg
Zeeland, Michigan
Expensive for sure. I opted for the RG-6 because of the performance/value factor. I guess there is the option to use UHF adapters which would give me more arrestor options but that may not be the best plan either.
jeepsandradios
East of the Mississippi
Id rather use an expensive polyphaser and know it works than a $30.00 amazon one hoping it will work. If your worried about protecting equipment skimping on the devise doesn't make sense to me. If you walk into pretty much any LMR tower site you will see polyphasers on every line from GPS to Lowband radios. They work and they work good.
CHHTX
Donna TX
A little confused with that first one. Do you not have to use a ground wire and connect it to a rod (or something metal that's ultimately in the ground)? Looking at their Install Guide, it doesn't mention that or show it anywhere.
Yes, they all need to be grounded.
That one is designed for bulkhead mounting. Usually at a radio site, there is an entrance panel where the coaxial cable enters the building. Those bulkheads are grounded. This protector would be grounded through the mounting.
You can get mounting brackets for it, but I neglected to include that part. Good catch.
rural_radio
¿Por qué no Ø?
GA
God, those are expensive.
I totally agree about the quality of PolyPhaser's products, but I guess it depends what kind of equipment is on the other end of the coax as far as whether or not they're expensive. They're pretty much standard in LMR systems, and I wouldn't even hesitate to use them on a nice amateur station, but I can see how it would be hard to justify that price if there was only a Baofeng or an inexpensive scanner on the other end.
If the OP is on an RG-6 kinda budget, and replacing the receiver would be cheaper than installing a PolyPhaser, I would even consider just using the type of grounding block typically used when a satellite or CATV line enters a building.
prcguy
This should be fine for RG6 at $25:
The main goal is to ground the outer shield of the coax and this has basically the same replicable gas plug as many other brands to protect the center conductor path.
JoshuaHufford
Jefferson City, Mo
CanesFan95
Analog already is interoperable.
FL
I use Diamond arresters and they're like half the cost of PolyPhasers.
